random speed downs from normal 8-9Mbps to 2-5Mbps and disconnections
- ADSL Broadband
- Re: random speed downs from normal 8-9Mbps to 2-5M...
25-04-2017 12:21 PM
these started to occur few days ago, and I did the usual, telephone tone ok, change filter, reset routers to factory settings -- nothing seemed to work and the disconnection is getting more frequent
Mode: ADSL_2plus
Traffic Type: ATM
Status: Up
Link Power State: L0
Downstream Upstream
Line Coding(Trellis): On On
SNR Margin (1 dB): 2.6 6.1
Attenuation (1 dB): 25.5 13.7
Output Power (1 dBm): 0.0 12.8
Attainable Rate (Kbps): 10420 1240
Path 0 Path 1
Downstream Upstream Downstream Upstream
Rate (Kbps): 9817 1230 0 0
MSGc (# of bytes in overhead channel message): 59 10 0 0
B (# of bytes in Mux Data Frame): 151 28 0 0
M (# of Mux Data Frames in FEC Data Frame): 1 8 0 0
T (Mux Data Frames over sync bytes): 2 6 0 0
R (# of check bytes in FEC Data Frame): 12 8 0 0
S (ratio of FEC over PMD Data Frame length): 0.4937 6.0000 0.0 0.0
L (# of bits in PMD Data Frame): 2657 320 0 0
D (interleaver depth): 64 4 0 0
Delay (msec): 8 6 0.0 0.0
INP (DMT symbol): 1.00 0.00 0.0 0.0
Super Frames: 14581 12948 0 0
Super Frame Errors: 2214 0 0 0
RS Words: 1895393 156541 0 0
RS Correctable Errors: 1264538 6 0 0
RS Uncorrectable Errors: 5160 0 0 0
HEC Errors: 2989 0 0 0
OCD Errors: 0 0 0 0
LCD Errors: 0 0 0 0
Total Cells: 5415705 670474 0 0
Data Cells: 2426419 112637 0 0
Bit Errors: 0 0 0 0
Total ES: 210 0
Total SES: 13 0
Total UAS: 81 81
switched to old Technicolor TG582n
DSL Connection
Link Information
Uptime: 0 days, 0:03:13
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 1,230 / 9,274
Data Transferred (Sent/Received) [kB/MB]: 545.74 / 6.85
Output Power (Up/Down) [dBm]: 12.8 / 0.0
Line Attenuation (Up/Down) [dB]: 13.5 / 25.0
SN Margin (Up/Down) [dB]: 6.1 / 3.1
Loss of Link (Remote): -
Error Seconds (Local/Remote): 138 / 0
FEC Errors (Up/Down): 0 / 765,743
CRC Errors (Up/Down): 0 / 1,242
HEC Errors (Up/Down): 0 / 796
the output power downstream is 0?
Any ideas? Many thanks,
Re: random speed downs from normal 8-9Mbps to 2-5Mbps and disconnections
25-04-2017 12:25 PM - edited 25-04-2017 12:36 PM
I'm just running a few tests on your line.
[edit]
Our tests aren't showing any obvious cause but I can see your fault has gone through to our Faults team and they'll investigate further.
- ADSL Broadband
