profile question
- profile question
profile question
13-02-2010 12:36 PM
How long should it take for my PN profile to catch up with the BT profile..?
Download speedachieved during the test was - 2908 Kbps
Additional Information:
Your DSL Connection Rate :6144 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 5000 Kbps
Phone exchange:
MANNINGTREE
Estimated line speed:
3.0 - Checked on 2009-09-09 20:39:18
Current line speed:
3500
i thought it was very quick it the speed difference was significant?
Phone exchange:
MANNINGTREE
Current line speed:
3500
Message 1 of 8
(1,516 Views)
7 REPLIES 7
Re: profile question
13-02-2010 12:55 PM
The bigger the increase in sync speed, the quicker BT's system will adjust your IP Profile upwards. This has already happened - 5000 is the correct profile for your 6144 sync.
PN's system is normally updated twice a day, regardless of the size of the increase.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
Message 2 of 8
(616 Views)
13-02-2010 2:38 PM
this is what i still see :
Phone exchange:
MANNINGTREE
Current line speed:
3500
could the PN profile be stuck?
Phone exchange:
MANNINGTREE
Current line speed:
3500
Message 3 of 8
(616 Views)
13-02-2010 2:43 PM
possibly but at present it only gets updated once per day so I would leave it until tomorrow to see if it has changed
Message 4 of 8
(616 Views)
13-02-2010 2:51 PM
I hadn't heard about the updates now being once, not twice, per day, Jim. Do you know if that's temporary or permanent?
Message 5 of 8
(616 Views)
13-02-2010 3:23 PM
It was in a thread a while back and I have no idea about its permanence or otherwise
http://community.plus.net/forum/index.php/topic,82900.msg682438.html#msg682438
Message 6 of 8
(616 Views)
14-02-2010 10:48 AM
I've found the wait period for a Plusnet Profile to catch up with a BT Profile to be very variable; sometimes within 12 hours, but most commonly 1 to 3 days. I usually give up waiting after 2-3 days and ask PN to equalise the PN Profile, and they do it there and then (thanks Customer Support).
I really do wish that it was a definite equalisation every 12 hours.
Message 7 of 8
(616 Views)
15-02-2010 10:31 AM
Hi jack21,
This is something we're currently looking at, though there's no updates at present. We'll keep you posted though.
Message 8 of 8
(616 Views)
