product change
product change
just downgraded from pro to extra.
is it possible for someone to check to see if interleaving is still turned off?
thanks
9 REPLIES 9
Re: product change
Hi scottmg,
Although it's set to auto, it's currently on fast. By the way did you know you can add pro to your extra package for just £5.00 per month?
Jojo Smiley
Re: product change
can it not be on fast permanently? .. yeah I did know I just downgraded from it? lol. didn't see the point if it only helps with new games.
cheers
Re: product change
Hi scottmg,
Yes, you can turn it off completely, just raise a ticket for it. As for the pro add on, it's not just new games it's good for there's also no rate limits across all protocols which means download sites/servers/P2P traffic aren't restricted during peak hours.
Jojo Smiley
Re: product change
hi jojo,
ticket number 43149795
if your bored with nothing to do Wink
scottmg
Re: product change
Certainly not bored, and _certainly_ not lacking for things to do - but the order's placed for you and should complete tomorrow Smiley
Re: product change
thanks mate!
so im going to be on fastpath.. (interleaving turned off) so my xbox should be fine and dandy? Smiley
Re: product change
Quote from: scottmg
That's the plan! Smiley
Re: product change
just checking in case you permanently turned it on, just so I would die that little bit easier! haha Smiley has it all gone through now?
Re: product change
Hi scottmg,
It's showing as completed now.
Jojo Smiley
