problems with email.......again
thebigyin
Is somthing wrong with the mail servers?
Evertime I login and try to read my mail I get an error telling me that I have to be loged in to access this page...... why?....... after all I have just logged in.
25 REPLIES 25
James
Re: problems with email.......again
Is this webmail or are you using an email application such as Outlook Express?
thebigyin
Its webmail. It seems to work for a bit then kicks me off, but all my other internet activities are not affected
maranello
I'm getting similar problems. Logged in successfully to Webmail, but get Login error when trying to view messages.
My other car isn't a Ferrari
ChrisDancer
I am having the same problem in webmail. Trying to reply or delete a message it tells me I need to log in.
I thought maybe our Russian friends were visiting again...
Chris
Legend
Fixes: 169
Thanks all, problem raised. I'll put the info in here when I've got some details.
Chris
Legend
Fixes: 169
P1 raised and can be seen here.
Oldjim
Resting Legend
Fixes: 63
Quick question (off topic) i can see that in the Service Status on the website but not yet on the RSS feed of Service Status from usertools
Is there a delay between the two or some other reason
Chris
Legend
Fixes: 169
There does always seem to be a slight delay with the service status tool propagating to usertools.
Tigger
This has actually got worse - I'm being logged out when I try to delete an e-mail, which it was doing OK.
Can't even read e-mail now, just see that it's there.
Angry Angry
Colin
Usertools tends to have it before bits of the website, but it depends on when the Service Status message is posted and which servers' automatic process gets it first.
PS - investigating the webmail issues as wlel.
thebigyin
any update yet guys? I really need to get to read some of my mails and because I am at a clients site I only have webmail access.
Chris
Legend
Fixes: 169
You can use Mail2Web as a temporary measure. From the link I've provided the mail server should be mail.plus.net (replace .plus.net with whatever VISP you are on). The username is your normal login name for webmail, as is the password.
netcareltd
The email system is discarding composed messages as soon as Send is clicked, and showing:
ERROR
You must be logged in to access this page.
Go to the login page.
It even happens if you try saving to Draft.
This is appalling.  How does such an error manage to happen?  Does PlusNet do no testing of changes made to the system?
Please let us know how long it will be be before this is fixed.
thebigyin
cheers Chris
