problems sending to yahoo mail from outlook
- problems sending to yahoo mail from outlook
03-03-2008 9:17 PM
Hi guys, just recently (last 3 weeks) sending via SMTP to yahoo mail worked intermittently, now it never works (last week). Receiving via POP is fine all the time. All is set up correctly according to yahoo help, in fact I didn't change the settings for some time. Incoming is 995 and outgoing 465. Outlook test also fails. Nothing changed in the PC as far as I know, scanned for every virus/bug/adware known to man.
Anyone else had this problem or can offer any help?
thanks
richard
thanks
richard
Message 1 of 9
(4,607 Views)
8 REPLIES 8
Re: problems sending to yahoo mail from outlook
03-03-2008 9:23 PM
Well, from the ports I can see they are not our servers, so can't provide direct assistance.
However, for myself and the wider audience to assist, can you provide the full error messages returned when you have problems.
Message 2 of 9
(1,222 Views)
03-03-2008 9:49 PM
hi phil, thanks for your instant reply! For my understanding does that mean each mail supplier uses different ports?
Anyway here is the error message sending and receiving from outlook 2003.
Task 'pop.mail.yahoo.co.uk - Sending' reported error (0x800CCC7D) : 'Your outgoing (SMTP) server does not support SSL-secured connections. If SSL-secured connections have worked in the past, contact your server administrator or Internet service provider (ISP).'
And here is the (same) error message sent from outlook 2003 test accounts
It suggests contacting you, also yahoo help suggests to ask you first in case any of these ports have recently been affected by upgrades and so on,
thanks richard
thanks richard
Message 3 of 9
(1,222 Views)
03-03-2008 10:01 PM
Looking at what you are saying, I don't believe this is anything we have done or which we can control. Googling the error brings lots of complaints like this one: http://answers.yahoo.com/question/index?qid=20080221054701AAFbSuW which point the finger at Yahoo.
Sorry I can't be more helpful on that one!
Ian
Ian
Message 4 of 9
(1,222 Views)
03-03-2008 10:54 PM
thanks very much, looks like a yahoo problem, but always best to check, and your response is simply stunning.
Probably have to move email accounts now!
have a good week
richard
have a good week
richard
Message 5 of 9
(1,222 Views)
04-03-2008 3:46 AM
I use Outlook Express with Yahoo mail on the ports mentioned with no problems (at present!).
Message 6 of 9
(1,222 Views)
04-03-2008 12:39 PM
One thought have you fully reloaded Windows? In the past I have found problems when I hibernate Windows and come back next day.
Message 7 of 9
(1,222 Views)
04-03-2008 11:41 PM
thanks no still utterly dead, but receive is fine!
Message 8 of 9
(1,222 Views)
05-03-2008 11:25 AM
I can shed a little light on this - I've had several calls from customers in the last few days who are having problems with Yahoo mail, both sending via SMTP, access via webmail, you name it. The ONLY common denominator is Yahoo - they're obviously having big problems with email, which frankly is not unusual.
Only thing you can do is wait until they sort it out (you'll know when that is - you'll see a thin film of ice forming on the upper surface of Hades) or change your email arrangements to another provider. Googlemail is good....
.....or Plusnet?
.....or Plusnet?
Message 9 of 9
(1,222 Views)
