problem with broadband speed (not just pcl-ag04)
- problem with broadband speed (not just pcl-ag04)
21-09-2009 7:52 PM
sync: 7616000
stable rate: 6500
snr: 15.5
loop atten: 9dB
exchange: green
Interleave on (according to my router )
legacy BB+
usage this month: Peak ~100MB Off:~12MB
Very poor responses on pcl-ag04: impossibly slow browsing, so ran a couple of BBMAx speedtests: 357 down/ 97 up & 348 down / 365 up
then gateway hopped to thn-ag3: 5979 down / 372 up
Had this last night as well, at about the same time, but even slower c. 127 down / 80 up, but later without a hop it improved (still on ag04) to 5900ish
Re: problem with pcl-ag04?
22-09-2009 9:45 AM
We're certainly not aware of any issues specifically affecting that gateway. Bob's going to mention it in our daily operational review though to see if anyone else if aware of any problems.
Re: problem with broadband speeds ...
22-09-2009 6:00 PM
so it's not a pcl-ag04 specific problem, but ... there is a problem.
sigh
Re: problem with broadband speed (not just pcl-ag04)
22-09-2009 7:22 PM
23-09-2009 6:52 PM
Download speedachieved during the test was - 4808 Kbps
Additional Information:
Your DSL Connection Rate :7616 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 6500 Kbps
24-09-2009 2:45 PM
I'm On BBYW 2
24-09-2009 6:30 PM
I'm confused -- and will raise a ticket, fwiw
25-09-2009 11:09 AM
28-09-2009 7:11 AM
28-09-2009 9:44 AM
28-09-2009 10:33 AM
Generally I boot the router up and it stays on and logged on the same session unless the exchange disconnects or there's a power glitch; Overall I'm lucky enough to have a very very stable line only a few hundred metres from the exchange. I've clocked up sessions weeks (perhaps months) long in the past without experiencing problems of this nature .
Also worth remembering that I have tried gateway hopping to resolve this a few times and the difficulty has returned.
29-09-2009 7:19 AM
I'll report back when the problem reoccurs this evening
01-10-2009 12:55 AM
It's so slow and sluggish that I can't even get the PN Portal to open so I can log-in and check what gateway I'm on. Not that that should matter, the service we pay for should be constant across the board!
What's worse is that I schedule my larger downloads for this time of niight as to avoid using great chunks of my download limit, and as of right now I can't do that!
01-10-2009 6:33 AM
They've asked me to plug the router into the test socket and then call them ... trouble is I have no test socket in my master socket.
I asked what they would like me to do next (at 18:15 on Tuesday) and so far have received no response or answer.
01-10-2009 7:32 AM
