problem streaming
noddy8
problem streaming
Hi not sure if you can help but my connection ( even though it is slightly slower since changing to plusnet ) has been fairly stable until I try to stream television catch up on both iplayer or 4 OD the router reboots , I've tried a different router and it's just the same  Cry any idea's cheers
17 REPLIES 17
adamwalker
Fixes: 221
Re: problem streaming
Hi noddy8,
I've taken a look at your account and can see the issue straight away.
For some reason which I'm yet to determine some details relating to our suppliers and the way your service is managed didn't update on your account when broadband was activated.
The "long and short" of this is that traffic management won't work properly resulting in streaming and speed issues got you amongst other things.
Sorry about this, I'm fixing it now. Please allow 10 minutes from my reply then disconnect/reconnect and you should see some improvement hopefully. I do however wish to set a reasonable expectation that the line is connecting at 2.5mb which is right on the estimate wev'e given you. That means streaming HD may sometimes be problematic (I'd download these if you have the option and stream in SD) also trying to do so on more than one device on the same connection would be a push too.
 Adam Walker
noddy8
Thanks for the reply will see what happens , we were getting a pretty stable 3mb connection previously but I know it's a long line
noddy8
we've never been able to stream in HD but had no real problems with SD and services like netflix , 4OD don't give a download option
noddy8
The noise margin seems to be stuck at 15 even after resync  Sad
cedlor
We might get a better idea of what is going on if you post the stats from your router (what make is it)
noddy8
Hi it's a 2wire 2700hgv is it best to just copy and paste the stats ?
cedlor
Yes - delete any personal details - if any
noddy8
don't think there's any personal bits in this
Modem Type: Built in modem - ADSL
DSL Line (Wire Pair): Line 1 (inner pair)
Current DSL Connection:
Down Up
Rate: 2880 kbs 448 kbs
Max Rate: 2744 kbs 792 kbs
Noise Margin: 15.0 dB 16.0 dB
Attenuation: 56.9 dB 31.5 dB
Output Power: 18.8 dBm 12.4 dBm
Protocol: G.DMT Annex A
Channel: Interleaved
DSLAM Vendor Information Country: {46336} Vendor: {TSTC} Specific: {4101 }
ATM PVC: 0/38
Rate Cap: 2744 kbs
Attenuation @ 300kHz: 56.9 dB
Uncanceled Echo: -18.2 dB Ok
VCXO Frequency Offset: -22.4 ppm Ok
Final Receive Gain: 33.0 dB Ok
Excessive Impulse Noise: 0 Ok
Traffic Statistics
IP Traffic Bytes Packets Errors %
Transmit: 1260618 185 0 0
Receive: 41953005 39618 0 0
ATM Traffic Cells Errors %
Transmit: 98870 0 0
Receive: 906141 0 0
DSL Link Errors
Collected for 4:31:34
Since Current Current Time Since
Reset 24-hr int. 15-min int. Last Event
ATM
Last Event
Cell Header Errors 3600 3600 28 0:00:01
Loss of cell Delineation 32 32 0 0:01:43
DSL
Link Retrains: 0 0 0 0:00:00
DSL Training Errors: 0 0 0 0:00:00
Training Timeouts: 0 0 0 0:00:00
Loss of Framing Failures: 0 0 0 0:00:00
Loss of Signal Failures: 0 0 0 0:00:00
Loss of Power Failures: 0 0 0 0:00:00
Loss of Margin Failures: 0 0 0 0:00:00
Cum. Seconds w/Errors: 3353 3353 23 0:00:01
Cum. Sec. w/Severe Errors: 0 0 0 0:00:00
Corrected Blocks: 36654 36654 218 0:00:01
Uncorrectable Blocks: 4573 4573 31 0:00:01
DSL Unavailable Seconds: 31 31 0 4:31:02
MatthewWheeler
Fixes: 479
Your target SNR is set at 15db so that won't change until DLM takes it off.
I can see quite a few errors on the line which most likely explains why it's set so high.
To rule out the obvious stuff first is your router connected to the master socket?
 Matthew Wheeler
noddy8
Yes it's straight in to the master socket via a filter plate
noddy8
any news on this yet ?
noddy8
still here waiting , anybody there ?
MatthewWheeler
Fixes: 479
I've put a reset through as the errors appear to be gone.
If you test it in a couple of hours there should be a increase.
 Matthew Wheeler
noddy8
Thanks for that sorry for delay had to turn router off for a few days but back on now  sync higher  Smiley I'll keep an eye on it cheers
