premium internet but 2mb/s speeds
- premium internet but 2mb/s speeds
14-03-2010 7:58 PM
I have done a number of speed tests on my connection and I am lucky to get over 2000 when I do it. Have a done something wrong as I thought I would get close to the line speed? My router says :
Modem Status Connected
DownStream Connection Speed 13238 kbps
UpStream Connection Speed 440 kbps
VPI 0
VCI 38
Phone exchange:
ABERDEEN DENBURN
Estimated line speed:
7 - Checked on 2010-02-28 22:21:09
Current line speed:
11000
So why is my connection so slow? Do I need to tick a box to move to ADSL2+?
VPI 0
VCI 38
Phone exchange:
ABERDEEN DENBURN
Current line speed:
11000
Message 1 of 5
(998 Views)
4 REPLIES 4
Re: premium internet but 2mb/s speeds
14-03-2010 10:44 PM
just did another test at 10:45pm
Download speedachieved during the test was - 1301 Kbps
For your connection, the acceptable range of speedsis 1000-99999 Kbps.
Additional Information:
Your DSL Connection Rate :13238 Kbps(DOWN-STREAM), 440 Kbps(UP-STREAM)
IP Profile for your line is - 11000 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 27.21:23.44:49.35 (SBE:NBE:PBE)
Message 2 of 5
(502 Views)
14-03-2010 11:13 PM
You are already on ADSL2+, connection speed would be no larger than 8128kbps if you weren't.
Both the IP profile shown by the BT speedtester, and Current line speed shown in the Member Centre are correct for your connection/sync speed.
The speed shown by the BT Tester could be wrong - perhaps just busy. What do you get from Plusnet's mybroadbandspeed tester http://www.mybroadbandspeed.co.uk?
David
Message 3 of 5
(502 Views)
15-03-2010 10:39 AM
That's really not good.
Everything on your account seems fine, so I've asked one of our faults guru's to take a look and see what the line tests say. I'll come back once I have an update.
Message 4 of 5
(502 Views)
16-03-2010 7:18 PM
download speeds have improved over last couple of days but now when connected to the playstation network i keep getting disconnected, very frustrating
Message 5 of 5
(502 Views)
