plusnet routers
- plusnet routers
plusnet routers
14-03-2014 4:00 PM
if so would plusnet send me a fiber router to replace my busted adsl one ?
Re: plusnet routers
14-03-2014 4:08 PM
Re: plusnet routers
14-03-2014 4:16 PM
Has it gone wrong again and you are already on ADSL2 from your previous post
Re: plusnet routers
14-03-2014 4:29 PM
Re: plusnet routers
14-03-2014 4:38 PM
Your line won't support ADSL2+
The only difference between the two is the higher frequency tones which will attenuate to nothing
Re: plusnet routers
14-03-2014 4:41 PM
Re: plusnet routers
14-03-2014 4:45 PM
Given the fact that you are getting multiple disconnections you may find that the reset will be rejected
As a matter of interest what speed did you get after the last reset
Re: plusnet routers
14-03-2014 4:51 PM
UpStream Connection Speed 864 kbps
ive had a new netgear router now for almost 2days with no disconnections so hope it stays that way
Re: plusnet routers
17-03-2014 8:44 AM
Re: plusnet routers
17-03-2014 9:58 AM
You are currently on ADSL2+ too.
Re: plusnet routers
17-03-2014 10:01 AM
Re: plusnet routers
17-03-2014 10:17 AM
Re: plusnet routers
17-03-2014 12:04 PM
just got back for town and checked router, seems like im getting alot of errors in the last 2hours
FEC Events (Down/Up): 0 / 0
CRC Events (Down/Up): 2014 / 37
HEC Events (Down/Up): 591 / 14
Error Seconds (Local/Remote): 6277 / 143
is this normal ?
Re: plusnet routers
17-03-2014 12:09 PM
If you are, I can apply Interleaving to tidy them up for you.
