please help!!!!! slow broadband speed
- please help!!!!! slow broadband speed
Re: please help!!!!! slow broadband speed
11-12-2007 6:01 PM
11-12-2007 6:03 PM
11-12-2007 6:48 PM
17:37 639 kbps (79.9kB/s) 329 kbps (41.1kB/s) Share
Powered by PlusNet. its a little better but still very poor,any advice???
11-12-2007 7:00 PM
Today 18:46 791 kbps (98.9kB/s) 362 kbps (45.3kB/s) Share
Today 17:37 639 kbps (79.9kB/s) 329 kbps (41.1kB/s)
done another test and its worse than ever!!!could i reboot my laptop (restore to factory settings) would that help????
11-12-2007 7:55 PM
Only if your operating system is Windows XP (or earlier) continue with this. Please run a tweaktest at DSLreports (here). To get the results select DSL, enter 8000, select your operating system, and leave Connection at normal. Just above the red text near the bottom of the results page you will be given a URL in small letters. Please copy and paste that here. Once I've seen that I'll provide further suggestions.
13-12-2007 10:15 PM
13-12-2007 11:06 PM
Does your router still show the same (excellent) connection stats as you posted before?
To eliminate your laptop as the source of the problem do you have an alternative computer to try (or a friend who could try theirs)?
15-12-2007 1:19 AM
16-12-2007 6:52 PM
17-12-2007 12:15 AM
Quote from: spraxyt … does your laptop run Windows Vista? If it does then the changes (tweaks) you've just done will have no effect.
Quote from: spraxyt Does your router still show the same (excellent) connection stats as you posted before?
… will help ensure we don't provide worthless information. What operating system did the second laptop have? That could show poor speeds, but for a different reason.
21-12-2007 5:42 PM
21-12-2007 11:42 PM
Then run DrTCP (which you downloaded on a previous occasion), and post the values shown in all the boxes (as an image if you know how to create one). I've attached an image of the DrTCP window from my computer; different values might be shown for some of your settings.
Note that though your sync speed might be 8Mbps the fastest *throughput* speed you will see is around 6.5Mbps because transmission overheads (ATM and TCP/IP + website connection management) must be subtracted from the sync speed. Admittedly that is considerably higher than you are experiencing now.
22-12-2007 4:06 PM
Latency Type Interleave Line Up Time 01:17:18:00
Line Coding Trellis On Line Up Count 1
Statistics Downstream Upstream
Line Rate 8096 Kbps 448 Kbps
Noise Margin 8.7 dB 21.0 dB
Line Attenuation 20.0 dB 9.5 dB
Output Power 19.8 dBm 12.1 dBm
22-12-2007 11:47 PM
23-12-2007 2:53 AM
