please help!!!!! slow broadband speed
- please help!!!!! slow broadband speed
10-12-2007 6:45 PM
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 192.168.1.2:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss)
I have a bt voyajer 2110.and im wireless
Re: please help!!!!! slow broadband speed
10-12-2007 6:52 PM
If you're unable to ping 192.168.0.2 it suggests an issue with your internal network, most likely your wireless throwing a wobbly.
If you reboot your router are you then able to ping that IP address?
Are you able to access http://voyager.home ?
10-12-2007 6:56 PM
10-12-2007 6:57 PM
10-12-2007 7:01 PM
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 192.168.0.2:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
10-12-2007 7:38 PM
Hope that helps,
10-12-2007 7:45 PM
Latency Type Interleave Line Up Time 01:21:09:20
Line Coding Trellis On Line Up Count 1
Statistics Downstream Upstream
Line Rate 8096 Kbps 448 Kbps
Noise Margin 8.6 dB 21.0 dB
Line Attenuation 20.0 dB 9.5 dB
Output Power 19.8 dBm 12.3 dBm
10-12-2007 9:04 PM
10-12-2007 9:39 PM
11-12-2007 12:30 AM
The IP address of your router should be 192.168.1.1. Using http://voyager.home/ takes you to that place and the stats you got there are excellent. Have those changed since you rebooted your router? Assuming the answer is no, answers to the following questions would help with diagnosis. Please retain the wired connection if you can.
Quote from: dazzy1503 Can anyone help, i have a problem with my broadband,iv done line tests and im getting results of 0.2mbps.
Are these "line tests" actually speed-tests? What results do you get if you do that on mybroadband speed here?
What value is shown as your current broadband speed on the portal here?
The final result that could help with diagnostics is a test on the BT speed-tester here. Unfortunately this site is very temperamental but if you can get them the results could be very helpful. The first page needs your phone number, the second username@realm as entered in your router set-up.
11-12-2007 9:27 AM
I've checked profiling settings at both ends and I'm seeing no reason why you should be seeing speeds that low.
As Mr. T (who isn't a fool) has suggested above please try running one of our speedtests over at http://mybroadbandspeed.co.uk
11-12-2007 5:41 PM
Today 17:37 639 kbps (79.9kB/s) 329 kbps (41.1kB/s)
11-12-2007 5:44 PM
11-12-2007 5:50 PM
In that case I would strongly suggest trying to tweak your MTU and rWin values.
I'd recommend going with an MTU of 1430 on both your router (which you should be able to set) and your desktop (using the software I'm about to post about).
rWin should be 111200.
You can set these using DR TCP.
11-12-2007 5:57 PM
