perfect connection gone bad
- perfect connection gone bad
Re: perfect connection gone bad
17-12-2010 2:50 PM
Are these what happened last time or have you tried the check I suggested this time, because we will need you to do that before we can raise a fault.
Jojo
17-12-2010 3:05 PM
Jojo I am going to go back to the test socket in a moment. cheers
17-12-2010 3:16 PM
21-12-2010 4:12 AM
Didnt change to the test socket because routerstats was showing flatlines.
21-12-2010 8:36 AM
28-12-2010 11:30 PM
BT's profile doesnt seem to want to budge from 750Kbps but PN has to 6000Kbps
I have had disconnections from line noise but always resynced over 6000Kbps
Getting pretty fed up with this now...
29-12-2010 10:03 AM
Just ran a line test and BT profile now back to 6000k. Are you seeing that at your end?
Jojo
29-12-2010 10:16 AM
Download speedachieved during the test was - 684 Kbps
For your connection, the acceptable range of speeds is 200-1000 Kbps.
Additional Information:
Your DSL Connection Rate :6912 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 750 Kbps
Been on 750Kbps since last friday.
Weird because PN was at 750Kbps.
29-12-2010 10:42 AM
29-12-2010 10:55 AM
I just ran some other checks and there is an inconsistency with your profile. I have one of our faults team raising this now for you.
Jojo
03-01-2011 8:27 PM
Going to ring for engineer appointment need this sorted.
04-01-2011 11:03 AM
We're just waiting for you to choose your appointment times now.
Jojo
04-01-2011 10:56 PM
Hope the noise exists when the engineer is here.
06-01-2011 12:42 PM
06-01-2011 1:00 PM
Yes, I'll do that now.
Jojo
