perfect connection gone bad
- perfect connection gone bad
07-10-2010 4:30 PM
connected to the master socket
got two bt2700hgv's ( swapped no difference )
standard phone connected only
no noise on the line
have had a faultless connection until now with a 7150 profile, reported no responce yet (35777110)
modem stats
Re: perfect connection gone bad
08-10-2010 10:28 AM
08-10-2010 1:46 PM
09-10-2010 9:42 PM
Any techs here can tell me different from looking at this attachment
10-10-2010 11:25 PM
I didnt notice this before only upon rebooting the router while on the phone i could hear adsl syncing.
High Resistance fault? what should i do now?
11-10-2010 12:47 PM
Are the router and the phone plugged through the same filter?
Jojo
12-10-2010 4:26 PM
Still can here adsl noise on phone and router reports uncanceled echo error.
Never had a probelm only from 30th Sept
Waiting for support to reply. down to 250kbps now.
12-10-2010 4:37 PM
Your connections have been a bit flakey and this has caused the BT profile to drop to 250, but with a current sync rate of 6432 it should lift to 5500 if the line stays stable.
I take it the phone on the extension has a filter on it?
Jojo
12-10-2010 4:55 PM
Tryed everthing i can. it must be an exchange fault.
12-10-2010 5:28 PM
I've got one of our faults guys to pick it up so you should get an update in about an hour.
Jojo
12-10-2010 9:48 PM
13-10-2010 11:30 AM
At the moment your sync rate is 16563 giving you the 14000. We can't manually bump it. The line will have to sync at 18176Kbps to get it back to 16000. Maybe try rebooting between 10am-2pm which could get the sync rate up.
Jojo
13-10-2010 4:38 PM
13-10-2010 4:44 PM
When you do reboot do it through your router interface via the disconnect/connect button and this will ensure the DLM doesn't see it as a drop.
Jojo
14-10-2010 4:15 PM
Will I hear from BT if they have looked at my line or will PN tell me first?
