over estimated speeds !!!!
- Re: over estimated speeds !!!!
- « Previous
- 1
- 2
- Next »
14-05-2013 9:44 AM
have you run a speed test from here http://speedtest.btwholesale.com/ ;
will also depend on what package your on
Message 16 of 20
(288 Views)
14-05-2013 9:48 AM
Are you trying to wind me up ?
Quote from: stewbett have you run a speed test from here http://speedtest.btwholesale.com/ ;
Message 17 of 20
(288 Views)
14-05-2013 9:50 AM
Looks to me as though he was trying to be helpful
Message 18 of 20
(288 Views)
14-05-2013 2:58 PM
Quote from: 30FTTC06 Are you trying to wind me up ?
Errrm no it was a simple question that might of helped you out !!
As you can see in my above posts running the BT speed test gives more information and clearly helped in finding finding out 1 of the problems that I was having in relation to my speeds, and looking through your posts I cant see that you have done one ! Im no expert in internet connection faults but another forum member could pick up on what the fault could be, as this was the case in my position. !
dick:green Quote fixed.
Message 19 of 20
(288 Views)
14-05-2013 3:18 PM
Sorry stewbett, it was uncalled for in your direction.
Message 20 of 20
(288 Views)
- « Previous
- 1
- 2
- Next »
