old wifi name still showing after router change
mikep72
Hello,
After experiencing WIFI problems with my last router Plusnet sent me out a new one, for the past 2 weeks this has been working as it should, however the only slight issue is that that then wifi network name still appears on the list and you can connect using the password I set.  Is there a way of removing it? With my new router I am running it (for now) using the default settings.
10 REPLIES 10
MasterOfReality
Fixes: 57
Re: old wifi name still showing after router change
HI @mikep72
Sorry, I'm a little confused here - do you mean that the WiFi name that was set to the OLD router is still showing your your list of available connections when you search for WiFi networks on your device?
I presume the old router is no longer plugged in?
Thanks,
MoR
Legend
Fixes: 255
I was tempted to ask that, @MasterOfReality  - but then I thought 'no, that just isn't possible', and decided to leave it to someone else.Wink
mikep72
Yes that is correct. My old WiFi name is still showing in the list of available networks on my devices and I still can connect using the password I set. I am very confused
Legend
Fixes: 255
@mikep72  I assume the old router is not still connected?
Is your new router showing?
mikep72
No it’s not plugged in and I have also noticed that it is also broadcasting the current WiFi name as a secured and unsecured network. I am obviously connected to the secured one!
mikep72
I have stopped it from showing an insecure network, my 5ghz network didn't have WPA2 turned on!!
Gel
Aspiring Champion
Fixes: 29
If running Windows;
1.Click the Network icon at the lower right corner of your screen.
2.Click Network/Internet settings.
3.Click Manage Wi-Fi settings.
4.Under Manage known networks, click network profile you want to delete.
5.Click Forget.
That wireless network profile is deleted.
mikep72
I have found out what is broadcasting my old network SSID..it was a pair of TP link power line adaptors that weren't paired correctly. I have now set them up and the old name has disappeared from my list of available networks.
Legend
Fixes: 255
@mikep72 It happens.Wink
Glad you've sorted it.
pint
Whenever I've updated/changed my router ( or homeplug with wifi ) I've always changed the new router to the old network name and password, meaning that i dont have to change the settings on multiple devices, same network name (SSID) same password  different router
