no internet light on router
declan101
Hello
My broadband was disconnected last Monday in error. I got through to customer services today who have set me up with a new account. I also got an email under my new account name with the header "your broadband's ready to go"
I've unplugged my router and filters a few times. I've tested the landline. Pretty sure I've gone through all the steps I can but the internet light stays off on the router and I can't connect to the internet.
Can you please help?
6 REPLIES 6
Mustrum
Fixes: 76
Re: no internet light on router
Have you got a new username and if so have you entered it in the router?
Have you tried a factory reset on the router - pin hole on the back for 30 secs.
declan101
I'll try the factory reset, thank you. How do I eneter my new user id into the router?
declan101
factory reset didn't work but thanks
Alex
Fixes: 13
What router are you trying to use.
A Hub One or something else?
declan101
I think the brand is Sagecom Router 2704N.
I don't think it's a hub.
declan101
