newbie ,, does your router get warm?
- Re: newbie ,, does your router get warm?
31-05-2012 8:45 PM
ok its on my desk/ with plenty of air around it ,,
is it ok to get a taft warm?
never on than more than 30-45 mins.
Message 1 of 8
(2,072 Views)
7 REPLIES 7
31-05-2012 9:02 PM
When I had problems with my central heating my router was my foot warmer, so yes they get warm but they shouldn't get hot then they can get flaky. Get some rubber feet for it and raise it, it doesn't need much to help.
FTTP 500 regrade from Tues 28th November
Message 2 of 8
(1,116 Views)
31-05-2012 9:05 PM
Quote from: kdoug007 never on than more than 30-45 mins.
I hope that doesn't mean you are turning it on and off many times a day as it can have a detrimental effect on your speed.
Message 3 of 8
(1,116 Views)
01-06-2012 9:28 AM
Routers like all electrical devices do warm up after they've on a while, but don't worry they are built to take it and it's quite normal.
Just out of curiosity do you have a thermometer that you could use to take a reading next to the router? we'd be interested to know exactly how warm a taft is in all seriousness though if you can do that please let us know.
Message 4 of 8
(1,116 Views)
01-06-2012 9:46 AM
thanks for the reply.... i usually have the router on may be 2-3 times a day,,,its not boiling hot , just warmish
Message 5 of 8
(1,116 Views)
01-06-2012 10:34 AM
Ideally a router should be left on 24/7.
Message 6 of 8
(1,116 Views)
01-06-2012 11:20 AM
See here for some temperatures http://community.plus.net/forum/index.php/topic,101363.msg860047.html#msg860047
I measured 27C above room temperature for a TG582n
PeteB
PeteB
Message 7 of 8
(1,116 Views)
01-06-2012 8:06 PM
strat.. that was my typing , i meant to say ,, my pn router is always on ... my internet is not.
Message 8 of 8
(1,116 Views)
