new customer
- Re: new customer
new customer
02-08-2007 4:27 PM
Quote Hi there,
If you maintain those sync speeds, you should see an improvement in profile and therefore throughput in the next day or so.
I'm still and have been on 250 kbps since Sunday. Should I wait more ?
Today's test result on the BT website is the following ;
Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 250 kbps
DSL connection rate: 448 kbps(UP-STREAM) 2240 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 223 kbps
And yesterday ;
DSL connection rate: 448 kbps(UP-STREAM) 2464 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 220 kbps
Is there anything you can do or I just have to wait, wait, wait... oups sorry !
cheers, Nicolas
Re: new customer
02-08-2007 4:29 PM
If it's still showing the same this time tomorrow, give us a shout and we'll raise it to BT as a fault as the bRAS seems to be stuck.
Re: new customer
02-08-2007 4:32 PM
If there is no progress tomorrow it's probably going to need to be raised to BT as a fault.
Re: new customer
02-08-2007 4:37 PM
Re: new customer
03-08-2007 10:11 AM
IP profile for your line is - 350 kbps
DSL connection rate: 448 kbps(UP-STREAM) 2208 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 317 kbps
The speed is still over 2000 but the IP profile has been updated from 250 to 350. I'd really like to surf normal speed, could you raise a fault to BT so I can use my connection this week-end ?
cheers, Nicolas
Re: new customer
03-08-2007 10:33 AM
Re: new customer
03-08-2007 10:48 AM
Re: new customer
03-08-2007 10:53 AM
Hope this helps,
Re: new customer
03-08-2007 2:17 PM
Re: new customer
03-08-2007 2:35 PM
Re: new customer
03-08-2007 4:33 PM
Re: new customer
03-08-2007 4:52 PM
