new broardband speed checker history
- new broardband speed checker history
14-02-2008 11:41 PM
Re: new broardband speed checker history
15-02-2008 10:39 AM
15-02-2008 10:43 AM
With these kind of results I'm ashamed to save them anyway
15-02-2008 11:13 AM
The history is tied to a cookie on your machine at present, so if you clear your cookies and cache you will lose your history.
We are currently identifying the best way to tie speed test history into the portal, in the same way that the old tester worked.
15-02-2008 11:33 AM
Strat, Your download is about the same as mine, and the upload is far better, so you ain`t alone, however, it would be nice to be able to see any significant changes in the history folder, to help with fault finding...
15-02-2008 11:46 AM
Quote from: Strat With these kind of results I'm ashamed to save them anyway
I have the opposite problem:
We are thinking of moving and losing my current connection bothers me!
15-02-2008 10:52 PM
Lets hope you cage the cookie monster soon.
As i like to clear cookies and temp files for sercurity reasons.
15-02-2008 11:12 PM
I never clear my cookies but the "history" only saves the last 30 tests.
Also, it only uses the last 16 results for the graph.
I preferred the old version.
16-02-2008 12:05 AM
16-02-2008 1:24 AM
Quote from: jelv I'd rather have a limited number of accurate results than an unlimited number of rubbish results!
I'm not sure if the new one is at all accurate.
I get the same speed (almost) of between 3750 and 3850 kbps - regardless of the time of day.
This is regardless of having a sync rate of twice that figure and a BRAS profile of 6500.
16-02-2008 9:21 AM
Quote from: axisofevil
I`d rather be able to keep the history for at least a month......even "inaccurate" results are a record of what has been happening, even if they are 15% in error, that "inaccuracy" would be consistant throughout the results.....
16-02-2008 10:27 AM
Quote from: shutter even if they are 15% in error, that "inaccuracy" would be consistant throughout the results.....
That was part of the problem - the inconsistency for people with faster connections.
16-02-2008 12:14 PM
Quote from: axisofevil Also, it only uses the last 16 results for the graph.
Only for the line graph.
For those wanting to save their results for eternity, why not use the "download this data" option?
16-02-2008 3:00 PM
I only count about 15 points - but 30+ are available.
16-02-2008 4:49 PM
jono
