network saturated overnight?
- network saturated overnight?
06-05-2008 5:20 AM
If the network is getting swamped maybe it's time to implement a FUP for the free overnight use too?
Re: network saturated overnight?
06-05-2008 8:39 AM
Sounds like something might be wrong specifically on your line. The network has at least 30% free space at the that time of the night. Have a look at the third graphs down on this page and you can see it isn't network congestion causing this...
http://www.plus.net/support/network_performance/broadband_bandwidth_usage.shtml?supporta=networkpbro...
06-05-2008 10:04 AM
06-05-2008 3:30 PM
06-05-2008 3:32 PM
Could this be a problem with the particular PN gateway you are connected to?
SW.
3Mb FTTC
06-05-2008 3:39 PM
http://bbs.adslguide.org.uk/showthreaded.php?Cat=&Board=plusnet&Number=3344539&page=0&view=expanded&...
06-05-2008 4:00 PM
We can't see anything obviously wrong, but Dave's looking into this over the course of this afternoon and we'll keep monitoring the situation.
06-05-2008 4:16 PM
I just disconnected my plus.net line for 15 minutes (web speeds were 100KB/s)
Connected to my Zen line and downloads were running full speed
Just reconnected my plus.net line and it's now running full speed again.
I assume the 20-25 minutes would have allowed me to connect to a different gateway?
06-05-2008 4:18 PM
06-05-2008 4:21 PM
This table shows how the different rate limits on advanced traffic are being applied during different times of the day.
HTTP speeds should always be prioritised though.
06-05-2008 4:26 PM
I'm on BBYW Option 3 with Max Premium.
06-05-2008 4:30 PM
Is that on P2P speeds? HTTP speedtests?
06-05-2008 4:36 PM
The 140KB/s download completely saturates the connection too. Everything else lags with it going on in the background.
06-05-2008 4:41 PM
Do you get decent results running the BT Speedtester with nothing else running in the background?
06-05-2008 5:08 PM
Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 7000 kbps
DSL connection rate: 832 kbps(UP-STREAM) 8096 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 6384 kbps
Why is the IP profile set to 7000 kbps? I should be able to achieve the maximum on my line. It's right next to the exchange and the line stats were described as exceptional when I signed up.
