mybroadbandspeed.co.uk upload test faulty?
- mybroadbandspeed.co.uk upload test faulty?
13-06-2011 1:21 PM
Currently testing a new router at the moment and the BT tester is showing all is well and same for thinkBB. But mybroadbandspeed.co.uk at around 80% of the upload test is its almost halving the speed every time, dropping the expected 46kb/s to 27kB/s
Anyone else seeing the same?
FTTP 500 regrade from Tues 28th November
Message 1 of 7
(1,455 Views)
6 REPLIES 6
Re: mybroadbandspeed.co.uk upload test faulty?
13-06-2011 3:20 PM
Not quite, but mine always says Up at 377K when the router says 488K! Not seen any thing different for long time and presume that it is a function of how it works.
Message 2 of 7
(457 Views)
13-06-2011 3:47 PM
Hi Colin,
That's pretty normal. Your router is saying that the speed it is synchronising with the exchange at is 448Kbps. 377Kbps is perfectly normal as they're always a sliught degradation.
Gus - I tried from the office earlier and didn't see any of those symptoms.
Message 3 of 7
(457 Views)
13-06-2011 4:35 PM
Quote from: Gus Anyone else seeing the same?
Yep, seeing the same thing here. Gets to about 75% through the upload test and then the speed drops to ~220kbps.
Message 4 of 7
(457 Views)
13-06-2011 7:35 PM
the attached is what I'm getting, was checking to see if its a quirk of this router or if its the site its self
Message 5 of 7
(457 Views)
13-06-2011 8:47 PM
not seeing the same on this vm connection yet speedtest will randomly chuck a frozen test out.
2 tests done with each browser top down chorme, IE 9, FF chrome is all always best including running HD content
Today 20:44 31648 kbps (3.96MB/s) 3138 kbps (392kB/s) Share
Today 20:44 31761 kbps (3.97MB/s) 3122 kbps (390kB/s) Share
Today 20:43 31659 kbps (3.96MB/s) 2963 kbps (370kB/s) Share
Today 20:43 31654 kbps (3.96MB/s) 3002 kbps (375kB/s) Share
Today 20:38 31666 kbps (3.96MB/s) 3016 kbps (377kB/s) Share
Today 20:38 31671 kbps (3.96MB/s) 3000 kbps (375kB/s) Share
Message 6 of 7
(457 Views)
13-06-2011 9:32 PM
I have been testing with FF 3.6 and IE 8 and can't recreate, so it seems to be a quirk of Opera 11.11
Message 7 of 7
(457 Views)
