my connecton speed
- my connecton speed
my connecton speed
07-07-2007 11:44 AM
My connection speed:
Is it just me that has this problem, on a good day upto 3400 kb/s and a bad day 133 kb/s download speed and my upload is around 384 kb/s but today it's 22 kb/s
Message 1 of 6
(7,250 Views)
5 REPLIES 5
Re: my connecton speed
08-07-2007 6:52 PM
Are you on LLU? There has been a problem with LLU speeds recently, details are here:
http://usertools.plus.net/status/archive/1183585155.htm
If you aren't on LLU can you run the BT Speedtest and see what result that gives?
http://www.plus.net/support/broadband/troubleshooting/bt_speed_tester.shtml
Dave Tomlinson
Plusnet Technology
Plusnet Technology
Message 2 of 6
(1,759 Views)
10-07-2007 7:46 AM
Message 3 of 6
(1,759 Views)
10-07-2007 10:48 AM
Packet losses of that magnitude will have a major impact on your speeds. The latency seems a tad high too. I've just done a test with the following result (on PAYG) .
My sync is 7392/448kbps profile 6500kbps.
To facilitate further comment please post your router stats (sync speeds, noise margins and attenuations - down and upstream). Mentioning the model of router would also help. I'd also recommend posting the results from a DSLreports tweak test (link).
Edit: to fix BBcode
Edit: to fix BBcode
David
Message 4 of 6
(1,759 Views)
10-07-2007 6:15 PM
Message 5 of 6
(1,759 Views)
10-07-2007 6:36 PM
Looking at those stats the first thing to try is the master socket (remove lower faceplate) as something is messing up your noise margin.
As a comparison these are my present figures
With your attenuation of 40.5dB you should be seeing much higher speeds.
Edit - just noticed your output power values - are these the wrong way round
The thing to note is that I have about the same speed with a slightly higher noise margin but my attenuation is 51dB.
Quote Bandwidth (Up/Down) [kbps/kbps]: 448 / 3,648
Output Power (Up/Down) [dBm]: 12.0 / 18.5
Line Attenuation (Up/Down) [dB]: 25.0 / 51.0
SN Margin (Up/Down) [dB]: 19.0 / 10.5
Message 6 of 6
(1,759 Views)
