moved house not heard anything in a week - supposed to have connection tommorow
- moved house not heard anything in a week - suppose...
Re: moved house not heard anything in a week - supposed to have connection tommorow
10-08-2015 2:23 PM
I've just checked again and it looks like the broadband should be online now as well
10-08-2015 2:26 PM
Thanks again
10-08-2015 6:52 PM
Any ideas?
10-08-2015 7:53 PM
Edit - did you get your router from PN - is there a booklet with it that tells you to ring a number (0800 number in mine but it is 2 yr old.)
when the green BB light is not lit.
11-08-2015 8:47 AM
Quote No Broadband or internet light showing.
Is the broadband light flashing? It should flash while it's trying to connect so if it's not then I'd suggest trying a different router.
If the light is trying to connect then can you let me know when you're available for an engineer visit? Mon-Fri, AM (8am-1pm) or PM (1pm-6pm).
11-08-2015 9:06 AM
No light flashing at all. Just the power light (and the ethernet light if the PC is connected). The phone line works. I have called to and from my mobile.
I don’t think I have another router.
Are we sure the line is active? If so I suppose I could buy a cheap one off amazon?
Thanks for your help.
11-08-2015 9:12 AM
Chris, It couldn't be that the router is configured for Fibre could it ? I'm not sure if/how the newer 2704 ones are set for ADSL/Fibre.
Quote No light flashing at all
11-08-2015 9:18 AM
I suppose the BT openreach socket could be the problem? But the phone works fine so to be honest I am not sure the broadband is live yet.
11-08-2015 9:58 AM
11-08-2015 10:05 AM
11-08-2015 10:10 AM
11-08-2015 10:36 AM
I'll see if maybe I can borrow someone's router.
11-08-2015 1:42 PM
The broadband light is not lighting at all, not flashing.
It seems to me the connection is NOT active.
Could it be that the local exchange is not connected?
I have:
- reset router to factory settings, twice.
- tried a different microfilter on the BT tes socket (by taking away the faceplate)
- turned off the router and the mains power about 20 times, waiting for 5 mins and rebooting
- using the router setup menu to diagnose the connection (DSL not in sync)
- disconnected the phone (which works fine btw)
Whatever I do the broadband light remains OFF, not flashing or lighting up whatsoever. The phone works, the wifi light is on and the router connects to my PC fine.
Therefore there is a faulty connection on the broadband, and let's be honest, 99% it is either the local exchange up the road (wherever that is) or the main exchange not setting the right switch. Faint possibility it is the BT master socker itself.
Please could someone let me know what to do?
As always, many thanks for any help.
11-08-2015 1:57 PM
11-08-2015 2:13 PM
