modem advice
- modem advice
modem advice
05-04-2011 10:15 PM
Re: modem advice
05-04-2011 10:25 PM
These are the settings rquired for the router to connect to plus net
http://www.plus.net/support/customer_service/using/settings.shtml?supporta=featconnsett
Usual way to access a router.. would be 192.168.1.1, or 192.168.0.1for general routers, 192.168.1.254 for bt hubs, you put either one of these IPs into the browser search bar (addressbar) works for I.E, or firefox not sure about the other browsers hope i helped abit...
Various passwords and usernames can be
username:admin/password: admin
username:admin/<leavepassword blank>
username:admin/password: password
Here is a site with additional information about the modem you posted with details on how to change the settings etc..
http://bt2700hgv.tripod.com/063.htm
Re: modem advice
05-04-2011 10:33 PM
Re: modem advice
06-04-2011 12:48 AM
Enter your Plusnet username and password/confirm password. All other settings should be OK. Scroll down to the bottom of the page, and you'll see a "Save" button, click it. You'll then be prompted for the router password. The default password for the BT Business Hub is the 12 digit serial number - depending on the model there may be a surplus "R" at the end of the SN field, which is not part of the password. Enter that, and click "Submit". If all is well, you'll get "Configuration Successful", and you'll be online.
If the router password has been changed, click on "I forgot the password". You should get a password hint. If not, or the hint doesn't help, click on "I still can't remember the password". This will take you to another page which asks for the WEP key, and a new password between 8-12 characters. When you have reset the password you'll have to go back to the beginning and repeat the process.
NB: I don't know if these routers work on Plusnet without modification - the sites mentioned in previous posts may help if that's the case.
(ETA more info)
Re: modem advice
06-04-2011 8:24 AM
Jaggies is almost correct in that all you need to do is enter your plusnet username/password. The problem with the 2700HGV(Business Hub) is that it is normally 'locked' to BT and will not accept your PlusNet details via the 'normal' configuration screens. The tripod site http://bt2700hgv.tripod.com/ir1002700HGV.htm gives all the details on how to get past the 'locking'. First thing you need to do is establish what firmware your 2700 is running as the methods to bypass the locking are different. The tripod site has all the information you need but if you have trouble then post back here.
BTW I've used a 2700 on PlusNet for a couple of years now and they are excellent routers.
Re: modem advice
07-04-2011 9:18 PM
Re: modem advice
12-04-2011 8:19 PM
Re: modem advice
13-04-2011 9:25 AM
