mail send problem : 550 relay not permitted
- mail send problem : 550 relay not permitted
08-04-2009 4:08 PM
Hi
My landlord at my secondary residence has changed ISP from BT Broadband to Sky Broadband. I am now finding that sending email through relay.plus.net now fails with an undeliverable, the message in which is 550 relay not permitted
I can receive OK.
The Outlook 2003 test account settings finds the SMTP server but fails to send the test email, asking to verify the email addess field.
Is this a particular problem with relay.plus.net not accepting emails from the Sky network, I wonder. Like I said it worked fine from BT and also O2 broadband, with the SMTP server set to not requiring authentication (though it will not accept the authentication if I do tick that checkbox)
Stuart
I can receive OK.
Stuart
Message 1 of 4
(2,047 Views)
3 REPLIES 3
Re: mail send problem : 550 relay not permitted
08-04-2009 4:15 PM
Hi Stuart,
As you're on Sky Broadband you will only be able to use our relay server if you set authentication to yes, and this will only work if you are on a subscription account with us. If we didn't have these measures in place our mail servers would be 'open relays' and very very easy for abuse by spammers.
Message 2 of 4
(541 Views)
08-04-2009 4:35 PM
Thanks Chris. Any reason it works OK with O2 and BT Broadband?
Stuart
Stuart
Message 3 of 4
(541 Views)
08-04-2009 7:12 PM
BT Broadband works because of the Plusnet PAYG users on the RIN trial. We get BT IP addresses so the BT ranges had to be allowed.
Message 4 of 4
(541 Views)
