level3 routing sick again to USA?
- level3 routing sick again to USA?
22-05-2012 6:07 PM
tracing login server gls.lotro.com and forum http://forums.lotro.com/
Re: level3 routing sick again to USA?
22-05-2012 6:16 PM
[tt]tracepath gls.lotro.com
1: obsidian.localdomain 0.141ms pmtu 1500
1: 192.168.0.1 5.094ms
1: 192.168.0.1 2.449ms
2: lo0-central4.ptw-ag01.plus.net 50.284ms asymm 3
3: 84.93.253.99 50.214ms asymm 4
4: t2as2-tge4-4.uk-lon1.eu.bt.net 49.314ms asymm 5
5: t2as1-v102.uk-lon1.eu.bt.net 49.929ms asymm 6
6: 166-49-211-38.eu.bt.net 49.201ms asymm 7
7: xe-1-2-0.bos11.ip4.tinet.net 132.084ms asymm 13
8: internap-gw.ip4.tinet.net 133.396ms asymm 13
9: border1.te8-1-bbnet2.bsn003.pnap.net 133.870ms asymm 13
10: turbine-7.border1.bsn003.pnap.net 128.048ms asymm 14
11: 74.201.102.154 126.953ms asymm 15
12: 74.201.102.12 132.730ms reached[/tt]
23-05-2012 10:21 AM
23-05-2012 11:07 AM
23-05-2012 11:34 AM
23-05-2012 1:08 PM
23-05-2012 1:50 PM
Quote from: Gus On my router no...
And what about the network adapter of the machine you were tracing from?
If you run an nslookup from a command line then what server address is being used?
Bob>nslookup ntp.plus.net
Server: cdns02.plus.net
Address: 212.159.6.10 <--- What address do you have here?
Non-authoritative answer:
Addresses: 212.159.6.10
212.159.13.50
212.159.6.9
212.159.13.49
If that's set to an OpenDNS address then the addresses your router has acquired are irrelevant.
23-05-2012 6:13 PM
