latenecy doubled at 0700 Today speed drop of 20%
- latenecy doubled at 0700 Today speed drop of 20%
Re: latenecy doubled at 0700 Today speed drop of 20%
23-06-2014 3:32 PM
Quote from: Chris Have you raised a fault with us if there's a problem with your line?
There's no point.
I'll be told it manages a decent speed most of the time and hence no problem exists.
However, just in case - I'll raise a fault.....
Told you so...
23-06-2014 4:02 PM
@vilefoxdemonofdoom - IF that's the way you feel then you're probably best not raising a fault. If you want us to take a look, we will.
23-06-2014 4:05 PM
Tony
23-06-2014 4:53 PM
13-07-2014 6:39 PM
Some time now passed since drop and latency, presumably due to interleaving being on. Will the BTW graph now always be red ??
Its dropped speed more since the last exchanges on the board here, i'm now in the 25% area you mentioned. The ticket was closed some time ago.
Tony
See attached
14-07-2014 10:21 AM
Interleaving is set to Low at the moment, if Interleaving does remove itself, the sync rate should improve.
14-07-2014 12:18 PM
Are you able to ascertain what errors are stopping the DLM from putting me back where I was ? Its over 28 days now, so I doubt anything would now happen. Is the largest barrier not at 28 ?
Tony
14-07-2014 12:22 PM
We can't tell which errors are causing the DLM to keep Interleaving on, we don't have that level of information yet 😕
16-07-2014 12:53 PM
Speeds dropped again today. is there nothing that can be done ? Download fallen a chunk now
Tony
21-07-2014 4:50 PM
21-07-2014 5:04 PM
Thanks. I've raised a fault 88886976. I have tried to make it clear what I believe is happening!
Also attached latest screen grab of the BTW test. Whilst my download is just within the range quoted in the DSLchecker site, my upload however no longer is
Tony
23-07-2014 12:45 PM
Tony
23-07-2014 2:44 PM
Your ticket should be picked up within the next 24 hours.
23-07-2014 2:58 PM
Thanks, I'm away from tomorrow until weekend so I guess this will not get actioned until after,then assuming a response is needed from me
Tony
24-07-2014 5:45 PM
Over 24 hours since last post. Noting happened on ticket raised on the 21st at 1700 so that's 72 hours past ?
Tony
