latency increase
- latency increase
latency increase
04-06-2010 10:28 PM
Can anyone advise why pings appear to have increased over the last few weeks. I used to be able to acheive a healthy 19-21ms response times on pingtest and to bbc.co.uk, howeber having just tested now, the best I can muster is around 49. This is not particularly great when it comes to gaming.
Any ellacoya tweaking takien place recently, Id like my 20ms pings back please!
Message 1 of 7
(1,148 Views)
6 REPLIES 6
Re: latency increase
04-06-2010 10:31 PM
has interleaving been turned on for some random reason?
Message 2 of 7
(523 Views)
04-06-2010 10:49 PM
19-20ms is Xcellent,
rare best case result maybe
Pls, describe your setup a little please,
you could, post your routers stats page info
and info about interleaving may be discerned from this, hopefully
some comms info appears when these addresses are entered into your browser address bar:
{not forgetting username and password for the router/modem, possibly supplied or underneath the unit }
eg: ( addrs by router manuf.) include --
NETGEAR:, or- LINKSYS (I BELIEVE)
http://192.168.0.1/
Our own Plusnet equipment Thomson TG585 v6,7,8 supplied by PN:
http://192.168.1.254/
some older routers or 'business'y setups:
http://10.0.0.1/
info. might not be on 1st page, but on a page link on those above (eg stats, connection, DSL, broadband topics)
HTH
T.
stuff which looks like the attached from mine>
http://192.168.0.1/
http://10.0.0.1/
HTH
T.
Message 3 of 7
(523 Views)
04-06-2010 11:16 PM
@ Newthing
I must be one of the rare cases , best I got before interleaving was off was 41 on a good day.
C:\Users\Paul>ping www.bbc.co.uk
Pinging www.bbc.net.uk [212.58.246.160] with 32 bytes of data:
Reply from 212.58.246.160: bytes=32 time=16ms TTL=56
Reply from 212.58.246.160: bytes=32 time=15ms TTL=56
Ping statistics for 212.58.246.160:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 15ms, Maximum = 16ms, Average = 15ms
@ Chesterfield
Somethings definately gone to pot there , was your connection unstable a fair bit over the last few weeks? Like Asbo says perhaps interleaving was put back on to stabilise it?
@ Chesterfield
Message 4 of 7
(523 Views)
05-06-2010 7:37 PM
Quote from: paulpicks21 @ Newthing
i get 29-31ms to bbc.co.uk on this interleved 63db atten line thats hooked upto the post office
Message 5 of 7
(523 Views)
05-06-2010 8:03 PM
Nothing to add, but here are my current ping results to bbc.co.uk, typically 14.62ms !
Message 6 of 7
(523 Views)
08-06-2010 3:25 PM
Support have sent the request to have interleaving turned off for me.
I normally have a rock solid 8128 or occasionally I may get a sync of one level below this if I ever have cause to turn the router off.
I think I have identified what may have caused this turning back on of the interleaving. We have recently had some electrical work done at the house along with plumbing etc, and at several points during this work they had to shut the power off. I remembered things like pc's, sky+ box etc, but forgot the router.
The electrician at one point had to test several RCD circuits, resulting in the power going off and back on again a few times in quick succession. I think this could easily have upset the router and the exchange into thinking that I had connectivity issues.
Hopefully after its turned off again it should stay that way.
Message 7 of 7
(523 Views)
