is it possible to raise speed?
- Re: is it possible to raise speed?
17-12-2013 8:54 PM
i was just looking at what bt can offer and it says 54.6 mbs. Is it possible to raise my fibre broadband to that speed?. if yes please can plus net member raise it for me thank you. Im attaching screen shots of what I'm receiving currently and what bt says i can have.
Message 1 of 8
(1,118 Views)
7 REPLIES 7
17-12-2013 9:02 PM
duplicate post removed - the dreaded forum lurgi struck again
If you run the BT speed test - further diagnostics it will tell you your IP profile and that is probably as good as you are going to get
Message 2 of 8
(624 Views)
17-12-2013 9:04 PM
Hi iqramhafezji,
Like you my estimated line speed has risen, when i enquired about moving my speed to match this, i was told its not that easy for fibre, and if needed raise a 'fault', i decided against this!
Message 3 of 8
(624 Views)
17-12-2013 9:12 PM
well i be honest with you mark i've had it done before, i haven't raise any fault. check this post http://community.plus.net/forum/index.php/topic,115739.msg998479.html#msg998479
dick:quote
dick:quote
Message 4 of 8
(624 Views)
17-12-2013 9:16 PM
You were incorrectly provisioned last time.
Message 5 of 8
(625 Views)
17-12-2013 9:18 PM
Thanks for that, my estimated line speed has risen to 59 down, and 18.6 up, but the best i can achieve is about 51 down, and 16 up, not complaining as service has been first class, just thought it would be easy to optimise the setting to best of my lines ability, as obviously something has happened at my cabinet to increase my speed.
Message 6 of 8
(625 Views)
17-12-2013 9:22 PM
why did you go against raising a fault? is there any down side raising a fault?
I will just give plusnet a call at some point when i can be asked, I don't really need that much speed so I may not bother.
Message 7 of 8
(625 Views)
17-12-2013 9:28 PM
No reason, im happy with speed, but as estimated line speed had risen, i thought fibre was similar to adsl, speed rises after re-boot of router/ modem.
Message 8 of 8
(625 Views)
