ip profile reset
- ip profile reset
ip profile reset
05-07-2012 1:00 PM
Hi there can someone arrange for my ip profile to be reset it seems to be stuck at 1.6meg and should be over 2meg. Thanks in advance. Tony
Message 1 of 6
(6,479 Views)
5 REPLIES 5
Re: ip profile reset
05-07-2012 1:17 PM
I'm afraid the systems we'd normally check your profile with are down at the moment, any chance you can run a BT speed test (http://www.speedtester.bt.com) and post the results in here, particularly the line profile? We'll happily set it to match if so.
Message 2 of 6
(689 Views)
05-07-2012 1:22 PM
Ahah! Never mind, found a working test Your profile has been upped to 2000 to match the current one on your line. Hope that improves things for you.
Message 3 of 6
(689 Views)
05-07-2012 2:15 PM
Thankyou very much!
Message 4 of 6
(689 Views)
01-03-2015 6:11 PM
I recently had a fault fixed and moved onto a different node thats less congested my profile is stuck at 2 megs and should be 7-8 megs can you please increase or reset so it can stabalise back to normal 7150 ty, my username is my broadband user name
Message 5 of 6
(689 Views)
02-03-2015 11:00 AM
Message 6 of 6
(689 Views)
