ip profie not updating
- ip profie not updating
08-11-2010 6:17 PM
my plusnet ip profile is stuck at 1250.
we had a power blackout a week ago while i was at work and my router resynced at 1650 so bt lowered my profile
resynced the router and waited 3 days run a bt speedtest and my profile was up to 7000
however my plusnet ip profile is still a 1250 why is that
Message 1 of 5
(682 Views)
4 REPLIES 4
Re: ip profie not updating
09-11-2010 2:58 PM
Hi jingo11,
Your BT profile has been set at 1250 since the 1st November. If you've maintained a steady sync rate with no connection drops since then I'd be happy to reset the SNR on your line and start the training period again?
Message 2 of 5
(340 Views)
14-11-2010 8:46 AM
my id profile is still not updating still at 1250
have had no lost of connection except 2 trying to
resync my router.bt speedtest shows
Download speedachieved during the test was - 1065 Kbps
Additional Information:
Your DSL Connection Rate :8096 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 7000 Kbps
can you please help
can you please help
Message 3 of 5
(340 Views)
14-11-2010 9:55 AM
Ring support and ask for your current line speed to be set to match your IP Profile. If they try to tell you you have to wait for up to 3 days make it clear that it is already longer than that since the IP Profile went to 7000.
Message 4 of 5
(340 Views)
15-11-2010 3:44 PM
Hi jingo11,
You recently had a resync at 1696k which had kept your profile to 1250. If you stay connected now it should lift after 3 days.
Jojo
Jojo
Message 5 of 5
(340 Views)
