internet on digital tv box
- Re: internet on digital tv box
12-01-2014 8:01 PM
anyone experienced any problems with connecting to the internet through a digital tv box? i had it working through plusnet but on a BT homehub router, but now that i've switched to the plusnet router it can't connect and says there's a problem with the connection to gateway. thanks
Message 1 of 2
(529 Views)
1 REPLY 1
12-01-2014 8:35 PM
Have you tried turning the TV box off and on again?
What IP address details does the box currently show?
Does it get an IP address automatically (by DHCP) or did you put one in manually?
If the latter, you'll need to change it to an address that starts 192.168.1.xxx
Message 2 of 2
(339 Views)
