internet keeps dropping after 10pm
FIXED- Subscribe to RSS Feed
- internet keeps dropping after 10pm
Re: internet keeps dropping after 10pm
14-04-2017 5:09 PM
I think there are enough graphs in this thread for us to see there are two different nights with different looking graphs at the same time of night.
14-04-2017 6:17 PM
just to keep the forum updated as to whats happening
I phoned Plusnet spoke to faults and
he said he has turned up SNR TO 12DB MIGHT TURN UP TO 1`5DB he said. also he said he set interleaving to MEDIUM and he was going to monitor it for 24hrs,ck let u know how i get on
ta
will get ba
14-04-2017 6:42 PM
Sight of the current DSL stats would be useful.
So they changed some settings which affect the DSL connection, what must have been the downstream target SNRM to 12 dB, and interleaving, medium is the standard level for interleaving being on. These are fairly typical actions to attempt to mitigate the problem without actually fixing the line or removing the source(s) of the interference, if there are actually any.
As usual, everyone else seems to completely ignore the issue with the upstream. We've seem the connection dropping, the downstream speed stays much the same each time, the upstream speed varies considerably - it should be obvious which one is the problem. Changing the downstream target SNRM isn't going to do anything to a problem with the upstream.
14-04-2017 6:51 PM
Sight of the current DSL stats would be useful...............
he told me to leave the new modem on for 24hrs so he can monitor it , so i cant run routerstats and tgn582 modem at moment.
will i get a stable and decent speed ?
so u reckon it will start dropping again
thanks
im getting fed up , dont feel im getting anywhere regarding a fix but i have learned alot if nothing else
14-04-2017 7:18 PM
@glesgajohn wrote:
I meant more stats consisting of the table of numbers from the modem, like those in the very first post.
It's possible they also capped the upstream speed to 448k or could try that, but I don't think any amount of interleaving or increased target SNRM will be enough to hide a problem as severe as this, so yes, unfortunately I'd expect the problem to continue.
14-04-2017 7:22 PM
Statistics -- xDSL
Mode: | ADSL_2plus | |||
Traffic Type: | ATM | |||
Status: | Up | |||
Link Power State: | L0 | |||
Downstream | Upstream | |||
Line Coding(Trellis): | On | On | ||
SNR Margin (1 dB): | 5.6 | 5.9 | ||
Attenuation (1 dB): | 39.0 | 23.4 | ||
Output Power (1 dBm): | 0.0 | 12.6 | ||
Attainable Rate (Kbps): | 11844 | 1052 | ||
Path 0 | Path 1 | |||
Downstream | Upstream | Downstream | Upstream | |
Rate (Kbps): | 9726 | 1053 | 0 | 0 |
MSGc (# of bytes in overhead channel message): | 92 | 67 | 0 | 0 |
B (# of bytes in Mux Data Frame): | 24 | 32 | 0 | 0 |
M (# of Mux Data Frames in FEC Data Frame): | 1 | 1 | 0 | 0 |
T (Mux Data Frames over sync bytes): | 8 | 1 | 0 | 0 |
R (# of check bytes in FEC Data Frame): | 4 | 6 | 0 | 0 |
S (ratio of FEC over PMD Data Frame length): | 0.0818 | 0.9719 | 0.0 | 0.0 |
L (# of bits in PMD Data Frame): | 2835 | 321 | 0 | 0 |
D (interleaver depth): | 384 | 32 | 0 | 0 |
Delay (msec): | 8 | 8 | 0.0 | 0.0 |
INP (DMT symbol): | 2.00 | 2.00 | 0.0 | 0.0 |
Super Frames: | 795015 | 713501 | 0 | 0 |
Super Frame Errors: | 583 | 0 | 0 | 0 |
RS Words: | 467949878 | 779573 | 0 | 0 |
RS Correctable Errors: | 125806 | 31 | 0 | 0 |
RS Uncorrectable Errors: | 1802 | 0 | 0 | 0 |
HEC Errors: | 489 | 0 | 0 | 0 |
OCD Errors: | 0 | 0 | 0 | 0 |
LCD Errors: | 0 | 0 | 0 | 0 |
Total Cells: | 219627649 | 23746836 | 0 | 0 |
Data Cells: | 5129878 | 724184 | 0 | 0 |
Bit Errors: | 0 | 0 | 0 | 0 |
Total ES: | 61 | 0 | ||
Total SES: | 10 | 0 | ||
Total UAS: | 161 | 151 |
so yes, unfortunately I'd expect the problem to continue.=
i can only wait and see hope not
will u kindly post back your thoughts on the stats above plze
14-04-2017 7:38 PM
Really not sure what has been done as opposed to what you believe you were told would be done. As of these stats, the SNRM is at the normal setting of 6dB and the synch speeds are fairly hot.
Expect disconnections!
@MatthewWheeler can you please advise of the proposed approach here?
15-04-2017 8:57 AM
The downstream may have been banded to 4864-9728 and has been given the greater than normal downstream INP of 2 (INP 1 is the usual on the downstream). The higher INP number indicates a higher amount of protection from noise. The downstream target SNRM is not really applicable with a banded speed, the only target SNRM with a banded profile is 6 dB, but the banding tends to limit the speed rather than the target SNRM.
The downstream interleaving depth is very high at 384, although this is not actually significant, because it's still the same 8ms delay, so the latency (ping times) will be the same as with ordinary interleaving levels.
The upstream is as normal, INP 2 is the standard level for the upstream.
So in summary, it's been given extra strong error protection on the downstream, and we'll have to wait and see if it's strong enough to fix / mitigate / workaround the problem.
15-04-2017 12:05 PM
@ejs,
An aside - Thank you that's really a very helpful insight on something that I did not register - can you point me to any easy to digest reference material on this please?
Cheers.
15-04-2017 4:18 PM
hi me again , yes you guesses, thats it started dropping again, started @ 3.20pm thats when i noticed it, faults guy was supposed to phone me today but not heard from him, yet .
Statistics -- xDSL
Status: | Up | |||
SNR Margin (1 dB): | -4.7 | 4.5 | ||
Attenuation (1 dB): | 39.0 | 23.5 | ||
Attainable Rate (Kbps): | 6904 | 1004 | ||
Rate (Kbps): | 9726 | 1024 | 0 | 0 |
MSGc (# of bytes in overhead channel message): | 92 | 64 | 0 | 0 |
S (ratio of FEC over PMD Data Frame length): | 0.0818 | 1.0000 | 0.0 | 0.0 |
L (# of bits in PMD Data Frame): | 2835 | 312 | 0 | 0 |
Super Frames: | 5460081 | 4906711 | 0 | 0 |
Super Frame Errors: | 61463 | 796 | 0 | 0 |
RS Words: | 14828798 | 1212004 | 0 | 0 |
RS Correctable Errors: | 8436 | 611 | 0 | 0 |
RS Uncorrectable Errors: | 255943 | 0 | 0 | 0 |
HEC Errors: | 300603 | 1874 | 0 | 0 |
OCD Errors: | 7 | 0 | 0 | 0 |
LCD Errors: | 7 | 0 | 0 | 0 |
Total Cells: | 6839994 | 704857 | 0 | 0 |
Data Cells: | 39996 | 12507 | 0 | 0 |
Bit Errors: | 0 | 5097 | 0 | 0 |
Total ES: | 1758 | 171 | ||
Total SES: | 1063 | 18 | ||
Total UAS: | 1677 | 594 |
15-04-2017 5:27 PM
Negative SNRM reported by the new router ... that does not inspire confidence!
15-04-2017 5:39 PM
hi Townman, what damage does that do ? the faults guy never phone back, typical !
cheers
15-04-2017 6:04 PM
Sorry, I am not aware of any such reference. There was the "ccSNR Best Practice Guide" which listed the rate bands with their available INP levels, but about a month ago BTWholesale changed their website so that almost everything requires a login for access.
16-04-2017 5:36 PM
hi again(still dropping )
checked stats
Statistics -- xDSL
Status: | Up | |||
SNR Margin (1 dB): | 8.9 | 9.0 | ||
Attainable Rate (Kbps): | 9900 | 972 | ||
Rate (Kbps): | 9262 | 972 | 0 | 0 |
MSGc (# of bytes in overhead channel message): | 59 | 65 | 0 | 0 |
B (# of bytes in Mux Data Frame): | 144 | 30 | 0 | 0 |
T (Mux Data Frames over sync bytes): | 2 | 1 | 0 | 0 |
R (# of check bytes in FEC Data Frame): | 10 | 6 | 0 | 0 |
S (ratio of FEC over PMD Data Frame length): | 0.4991 | 0.9866 | 0.0 | 0.0 |
L (# of bits in PMD Data Frame): | 2484 | 300 | 0 | 0 |
D (interleaver depth): | 64 | 32 | 0 | 0 |
INP (DMT symbol): | 1.00 | 2.50 | 0.0 | 0.0 |
Super Frames: | 11035074 | 9983111 | 0 | 0 |
Super Frame Errors: | 418567 | 3415 | 0 | 0 |
RS Words: | 2688391 | 1358130 | 0 | 0 |
RS Correctable Errors: | 443 | 0 | 0 | 0 |
RS Uncorrectable Errors: | 12 | 0 | 0 | 0 |
HEC Errors: | 7332107 | 8256 | 0 | 0 |
Total Cells: | 7330365 | 760513 | 0 | 0 |
Data Cells: | 249941 | 61384 | 0 | 0 |
Total ES: | 13646 | 793 | ||
Total SES: | 7146 | 61 | ||
Total UAS: | 7563 | 1831 |
has anything changed . also this is what they sent me
16-04-2017 5:50 PM
Considering the xDSL stats do not match the "Profile Info: 4M - 9M ..." details, I'm guessing someone has adjusted the parameters again. I'm assuming it's no longer on a banded profile, so has the standard downstream INP of 1, and they've set both the downstream and upstream target SNRM to 9 dB.
