internet drops every 10-15 minutes
- Re: internet drops every 10-15 minutes
13-02-2015 12:53 PM
Every 10-15 minutes the internet goes down for about 2-3 minutes. Kind of frustrating.
Is there a know issue in my area or is there something I should do?
Regards,
Cosmin
13-02-2015 1:55 PM
<img src="http://community.plus.net/visualradius/generated/image14238353887567.png"/>
Do you lose sync when the connection drops? Are these drops above when you've been rebooting by any chance?
13-02-2015 6:41 PM
13-02-2015 6:47 PM
However we haven't seen any disconnections since around 2pm. Are you seeing better stability from your side?
13-02-2015 6:55 PM
14-02-2015 3:25 PM
If there are crackles / hums / hissing on the line, then raise a noisy line fault with your phone provider, but say nothing about broadband issues.
