interleaving off on adsl2+
- Re:interleaving off on adsl2+
11-11-2009 5:09 PM
Before i had my interleaving turned off i was syncing around 22000 with a profile of 19000 i could through a stone at the exchange i am that close.
but ever since having interleaving turned of the dlm has changed my snr target everyday and is now at 22 giving me a sync of around 9000.
surely interleaving does not have this massive effect.
In my last house on a long line i only lost 1000kps of bandwidth from 7000 to 6000 when turning interleaving off.
Why on a better line is it having a worse effect?
Message 1 of 8
(1,987 Views)
7 REPLIES 7
Re: interleaving off on adsl2+
11-11-2009 5:13 PM
with you syncing so high it should'nt make a huge diffrence.
what the error counts like?
Message 2 of 8
(638 Views)
11-11-2009 5:16 PM
Hi Chris,
Generally an SNR of 22dB, suggests that you'll be on a banded profile.
Check to see if your connection is remaining stable over the next few days and we can ask BT to remove the band should there be one.
Message 3 of 8
(638 Views)
11-11-2009 5:32 PM
i recently got a new belkin router which dosnt seem to have an error log. (or i cant find it)
i use this router cause it gives me a higher sync and better ping but oddly enough a higher line Attenuation at 34 but on my other router it is 26.
Message 4 of 8
(638 Views)
11-11-2009 5:38 PM
my netgear reports a 3db higher atten than the thomson.
but i can only asume such a big diffrence likely that is due to the band or becuse of the extra tones your using with +
a belkin i brought and took back gave me a 1-2 ms lower ping over my netgear. but its settings you could play with was very limited and routerstats didnt work so i hunted high and low for another broadcom netgear v4
i find the broadcom chip be better on my long line
Message 5 of 8
(638 Views)
13-11-2009 2:08 PM
SNR is still at 22 for the 3rd day running now. were as it was being changed every day up until then could this be a banded profile then.
Message 6 of 8
(638 Views)
13-11-2009 4:00 PM
Hi Chris,
There is a banded profile on there (4-9mb). I'll see what I can do about getting that removed for you.
Message 7 of 8
(638 Views)
13-11-2009 4:28 PM
cheers
Message 8 of 8
(638 Views)
