how long should I wait before requesting an snr reset?
- Re: how long should I wait before requesting an sn...
04-04-2011 11:17 AM
I had my SNR reset when I moved to 21CN and saw my speed shoot up fantastically. A few weeks after I had issues with my line which BT replaced the d side on and my SNR has risen. My line is now stable once more and so is the connection. (Phew!)
Is there a certain length of time i should wait before requesting an snr reset to say 6db. I am well past the 10 days since my line was replaced.
any thoughts,
podman
any thoughts,
podman
Message 1 of 5
(7,823 Views)
4 REPLIES 4
Re: how long should I wait before requesting an snr reset?
05-04-2011 12:09 AM
Plusnet might be willing to do that now since a fault has been repaired and connection stability demonstrated.
David
Message 2 of 5
(456 Views)
05-04-2011 11:50 AM
Hi Podman,
I wouldn't like to reset it at the moment as the line is not that stable. Are you in the test socket?
Jojo
Jojo
Message 3 of 5
(456 Views)
05-04-2011 9:15 PM
HI Jojo,
from your pic it seams a heck of lot more stable than ut has been. Last nights blip was me leaving it off line for a while to see if i could increase line speed. Sync has risen but speed is down at the minute hoopefully see a rise soon.
podman
podman
Message 4 of 5
(456 Views)
06-04-2011 10:27 AM
HI Podman,
Looks like 30 minutes after your last post it went up to 5500k.
Jojo
Jojo
Message 5 of 5
(456 Views)
