how do I know if my upload is uncapped?
FIXED- Subscribe to RSS Feed
- Re: how do I know if my upload is uncapped?
25-08-2019 7:12 PM
I have a basic broadband package. I get about 18MPS down and 1 Mbps up. The download sped is more than adequate for my needs but backing up photos (large files from a DSLR) to the cloud is very slow. Is 1 Mbps as fast as my upload can go?
stuck
Fixed! Go to the fix.
25-08-2019 7:18 PM
Yes, unless you upgrade to Fibre.
Put your phone number in the DSL Checker to see what speeds your line can get.
25-08-2019 7:37 PM
OK, thanks for clarifying.
stuck
25-08-2019 11:12 PM
AFAIK Plusnet currently only offer a bit less than 10Mbps upload on fibre - which is less than 1MByte/sec - so uploads will still be "sluggish".
26-08-2019 1:45 PM
27-08-2019 10:21 AM
Providing your line will support it the fibre uptions are 'up to' 40/10 or 80/20Mbps
