how do I know if my upload is uncapped?
stuck
I have a basic broadband package.  I get about 18MPS down and 1 Mbps up.  The download sped is more than adequate for my needs but backing up photos (large files from a DSLR) to the cloud is very slow.  Is 1 Mbps as fast as my upload can go?
stuck
5 REPLIES 5
Mustrum
Fixes: 60
Re: how do I know if my upload is uncapped?
Yes, unless you upgrade to Fibre.
Put your phone number in the DSL Checker to see what speeds your line can get.
stuck
OK, thanks for clarifying.
stuck
VileReynard
Fixes: 20
AFAIK Plusnet currently only offer a bit less than 10Mbps upload on fibre - which is less than 1MByte/sec - so uploads will still be "sluggish".
Mads
Fixes: 79
Hey @stuck,
As confirmed by @Mustrum your upload speed generally won't be any higher than 1mbps, however, you can check speeds for both upload & download via this webpage here.
Thanks.
 Maddy S
Fixes: 227
Providing your line will support it the fibre uptions are 'up to'  40/10 or 80/20Mbps
