how can I protect my DSL from storms
magnetism2772
if its true
that if I surge protect my dsl, Its a waste of my time and will just drop my  SNR and raise my attenuation slightly.
should   i switch  it off , wait and let the storm fade ?
47 REPLIES 47
pierre_pierre
Re: how can I protect my DSL from storms
you can switch it off if you want, the odd 10 000 volt lightnig strike might with bad luck miss
VileReynard
Aspiring Champion
Fixes: 15
Telephones aren't surge protected, but they never explode.
Bang!
Lightning Strike
[Moderator's note by Dick(Strat) PLEASE NOTE the link contains strong language which may offend.
198kHz
Champion
Fixes: 15
Quote from: A
Oh yes they do!
Re OP:  I always power down if there's lightning about; the DSLAM won't mind one clean break, but could well throw a wobbly during a storm.
The impossible often has a kind of integrity the merely improbable lacks. Douglas Adams
pierre_pierre
just been looking through my Italian photo's, thought I had a daytime pic of a strike on a power cable outside our Garage, it hit the cable near a pole, travelled down the wire and blew up a transformers about 100 Metre from us
magnetism2772
some  fireworks
and i did earlier read on the  net
of a one wire internet with  a floating earth
that  still worked (not recommended)
creating a gap like a sparking plug
magnetism2772
thanks for the video  link
brill its something to show bored guests  Grin
pierre_pierre
used to use an adaptor on CB radio - a heavy adaptor with solid pins instead of wire, small gap and a side contact that you wired down to earth with a heavy cable.  never had a hit.
But no use at all for telephone.
Neighbour across the road had a hit on theirs, blew up a lot in the house, phones, router etc
pierre_pierre
Quote from: giro
a long as they are deaf
magnetism2772
thanks to all
the consensus is to switch the router off together with pc
and to remove their power plugs from the wall  sockets
pierre_pierre
not the power plus, the phone cable that runs between the poles up the street
magnetism2772
pierre do you mean
I need to disconnect  the adsl cable from the bt telephone socket?
pierre_pierre
if you are so clever, work it out
magnetism2772
understood and to make sure that my router is protected I will unplug both
both the power cable from the wall and the adsl cable form the bt phone socket
some video
