how can I protect my DSL from storms
- Re: how can I protect my DSL from storms
26-10-2010 5:35 PM
that if I surge protect my dsl, Its a waste of my time and will just drop my SNR and raise my attenuation slightly.
should i switch it off , wait and let the storm fade ?
26-10-2010 6:27 PM
26-10-2010 6:41 PM
26-10-2010 6:49 PM
Lightning Strike
[Moderator's note by Dick(Strat) PLEASE NOTE the link contains strong language which may offend.
26-10-2010 7:07 PM
Quote from: A Telephones aren't surge protected, but they never explode.
Oh yes they do!
Re OP: I always power down if there's lightning about; the DSLAM won't mind one clean break, but could well throw a wobbly during a storm.
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
26-10-2010 7:23 PM
26-10-2010 7:27 PM
and i did earlier read on the net
of a one wire internet with a floating earth
that still worked (not recommended)
creating a gap like a sparking plug
26-10-2010 7:31 PM
brill its something to show bored guests
26-10-2010 7:37 PM
But no use at all for telephone.
Neighbour across the road had a hit on theirs, blew up a lot in the house, phones, router etc
26-10-2010 7:37 PM
Quote from: giro thanks for the video link
a long as they are deaf
26-10-2010 7:49 PM
the consensus is to switch the router off together with pc
and to remove their power plugs from the wall sockets
26-10-2010 7:54 PM
26-10-2010 7:57 PM
I need to disconnect the adsl cable from the bt telephone socket?
26-10-2010 7:59 PM
26-10-2010 8:03 PM
both the power cable from the wall and the adsl cable form the bt phone socket
some video
