gateway hop on FTTC
- Re: gateway hop on FTTC
gateway hop on FTTC
20-11-2012 10:05 PM
Hey,
I haven't got my fibre yet but I just had a thought while looking at my ping. Is it possible to hop gateway while on FTTC? I understand the modem is BT's equipment, will I be able to login to the modem and read status and/or disconnect and re-connect?
Message 1 of 7
(2,608 Views)
6 REPLIES 6
21-11-2012 7:01 AM
You can disconnect your ppp session in the router.
Message 2 of 7
(647 Views)
21-11-2012 9:16 PM
Quote from: Blim
Plusnet will supply the router & BT will supply the modem.
The router will not provide the usual/familiar connection stats.
Gateway hopping can be achieved by disconnecting/reconnecting via the router, without actually causing the modem to resync.
Officially, the modem is locked down so connection stats cannot be obtained.
Unofficially the modem can be unlocked via a freely available firmware update & then all the connection's stats can be obtained (& graphed if required).
Message 3 of 7
(647 Views)
22-11-2012 12:21 AM
Is that possible for the new ECI modems B-FOCuS V-2FUb/r Rev. B ?
Message 4 of 7
(647 Views)
22-11-2012 12:27 AM
OK thanks, just thought Id check this before its too late.
I didn't select the router when I ordered my upgrade because I wasn't sure if it was just a firmware modded modem or not. I've got a router with PPPoE but its bit old. Saying that it does had DD-WRT firmware and QoS so it should be good. I don't use the duel band wireless n but house mates will. just ordered some new cables so I should be all geared up ready.
Message 5 of 7
(647 Views)
22-11-2012 11:03 PM
Quote from: mushy
Sorry, I should have stated the Huawei HG612 modem can be unlocked via a freely available firmware update & then all the connection's stats can be obtained (& graphed if required).
Apparently both versions of ECI modem can now be unlocked, but from remotely monitoring an unlocked original version, the data harvesting isn't too reliable yet & is in a completely different format than the HG612's typical Broadcom format.:-
=~=~=~=~=~=~=~=~=~=~=~= Plink log 2012.10.13 23:00:51 =~=~=~=~=~=~=~=~=~=~=~=
login as: admin
password:
BusyBox v1.00 (2011.08.09-03:28+0000) Built-in shell (msh)
Enter 'help' for a list of built-in commands.
Alpha #
Alpha # echo "g997lspbg 1" > /tmp/pipe/dsl_cpe0_cmd
Alpha # cat /tmp/pipe/dsl_cpe0_ack
nReturn=0 nDirection=0 LATN[0]=132 LATN[1]=305 LATN[2]=489 LATN[3]=-32768 LATN[4]=-32768 SATN[0]=117 SATN[1]=302 SATN[2]=484 SATN[3]=-32768 SATN[4]=-32768 SNR[0]=57 SNR[1]=56 SNR[2]=59 SNR[3]=-32768 SNR[4]=-32768
Alpha #
Alpha # echo "g997lspbg 0" > /tmp/pipe/dsl_cpe0_cmd
nReturn=0 nDirection=0 LATN[0]=2 LATN[1]=225 LATN[2]=364 LATN[3]=-32768 LATN[4]=-32768 SATN[0]=1 SATN[1]=223 SATN[2]=362 SATN[3]=-32768 SATN[4]=-32768 SNR[0]=68 SNR[1]=69 SNR[2]=63 SNR[3]=-32768 SNR[4]=-32768
Alpha #
Alpha # echo "g997listrg 1" > /tmp/pipe/dsl_cpe0_cmd
nReturn=0 nDirection=1 G994VendorID=IFTN SystemVendorID=ECI tele VersionNumber= SerialNumber=7035497883 SelfTestResult=0 XTSECapabilities=(00,00,00,00,00,00,00,00)
Alpha #
Alpha # echo "g997lsg 1 1" > /tmp/pipe/dsl_cpe0_cmd
nReturn=0 nLineState=0x801
Alpha #
Alpha # echo "g997lsg 0 1" > /tmp/pipe/dsl_cpe0_cmd
nReturn=0 nDirection=0 nDeltDataType=1 LATN=0 SATN=0 SNR=64 ATTNDR=21918632 ACTPS=-901 ACTATP=125
Alpha #
Alpha # echo "g997csg 1 1" > /tmp/pipe/dsl_cpe0_cmd
nReturn=-22Alpha #
Alpha # echo "g997csg 0 1" > /tmp/pipe/dsl_cpe0_cmd
nReturn=0 nChannel=0 nDirection=1 ActualDataRate=67868000 PreviousDataRate=73992000 ActualInterleaveDelay=975 ActualImpulseNoiseProtection=30
Alpha #
Alpha # echo "bbsg 0" > /tmp/pipe/dsl_cpe0_cmd
nReturn=0 nDirection=0 nNumData=3
nFormat=(nBandIndex, (nLimit_firstToneIndex, nLimit_lastToneIndex), (nBorder_firstToneIndex, nBorder_lastToneIndex)) nData="
(00,(0010,0031),(0010,0031))
(01,(0882,1193),(0882,1193))
(02,(1984,2770),(1984,2770))
Alpha #
Alpha # echo "bbsg 1" > /tmp/pipe/dsl_cpe0_cmd
nReturn=0 nDirection=1 nNumData=3
(00,(0033,0857),(0033,0857))
(01,(1218,1959),(1218,1959))
(02,(2795,3950),(2795,3935))
Alpha #
Alpha # exit
=~=~=~=~=~=~=~=~=~=~=~= Plink log 2012.10.13 23:07:33 =~=~=~=~=~=~=~=~=~=~=~=
login as: admin
password:
Alpha #
Alpha #
nReturn=0 nDirection=0 LATN[0]=2 LATN[1]=225 LATN[2]=364 LATN[3]=-32768 LATN[4]=-32768 SATN[0]=1 SATN[1]=223 SATN[2]=362 SATN[3]=-32768 SATN[4]=-32768 SNR[0]=68 SNR[1]=68 SNR[2]=63 SNR[3]=-32768 SNR[4]=-32768
Alpha #
Alpha #
nReturn=0 nDirection=1 nDeltDataType=1 LATN=185 SATN=153 SNR=58 ATTNDR=78415280 ACTPS=-901 ACTATP=65
Alpha #
nReturn=0 nDirection=0 nDeltDataType=1 LATN=0 SATN=0 SNR=64 ATTNDR=21915204 ACTPS=-901 ACTATP=125
Alpha #
nReturn=-22Alpha #
Alpha #
Alpha #
Alpha #
Alpha # exit
Message 6 of 7
(647 Views)
23-11-2012 10:20 PM
Thanks for that Bald Eagle, please let me know if that changes
Message 7 of 7
(647 Views)
