free usage
- Re: free usage
- « Previous
- 1
- 2
- Next »
Re: free usage
14-09-2008 6:10 PM
there is a peculiar hump around midnight, it is best to schedule downloads to start about 00:05, and switch of just before 08:00
Message 16 of 22
(459 Views)
Re: free usage
15-09-2008 6:46 AM
I know this has been raised before but ...... you can schedule Windows updates to install in the middle of the night but I'm not aware hat you can schedule the downloading???
Message 17 of 22
(459 Views)
Re: free usage
15-09-2008 7:09 AM
nor am I, I normally do mine manually so that I can check what they are doing first. Also the MS Tuesday updates are American origin and you cant guarantee when they are released in the UK.
Message 18 of 22
(459 Views)
Re: free usage
15-09-2008 8:03 AM
The setting is to automatically download and install not just to download.
Message 19 of 22
(459 Views)
Re: free usage
15-09-2008 11:07 AM
Hi Peter,
The way that CBC usage works is that we discount the "interim" update at the cut off between peak and off peak to ensure that no usage is charged for in the off peak period.
Message 20 of 22
(459 Views)
Re: free usage
15-09-2008 11:14 AM
Yes I did know that James, just that so many people ask the same question, it stops then saying, my VMBU is not working right
Message 21 of 22
(459 Views)
Re: free usage
15-09-2008 7:07 PM
Cheers
Yes the setting does indeed regulate download and install.
In my experience the downloads dont actually appear to become available in the UK until Wednesday (never checked Redmond time)
I do tend to like to do them manually but do like the idea of not having to pay for their transfer and I am definitely not staying up into the small hours to do it as shift working stuffs up your body clock more than enough!
Message 22 of 22
(459 Views)
- « Previous
- 1
- 2
- Next »
