fibre speed question
- fibre speed question
- « Previous
- 1
- 2
- Next »
Re: fibre speed question
02-02-2014 6:53 PM
^Yes ^ remove your number , do not want to give slammers any idea....
Message 16 of 24
(462 Views)
02-02-2014 7:02 PM
Funny enough http://www.kitz.co.uk/adsl/btwchecker.htm reports the exact same for my number as yours (Speed Wise). Yet my IP Profile is 51.6mb
It's all down to the line from cabinet to house, also the length. I was estimated 63Mb-80Mb, next door has BT infinity with the same speeds as me? So moving ISP won't solve anything
Message 17 of 24
(462 Views)
02-02-2014 7:12 PM
well my next door but one has BT infinity and has almost 80mb same post same cabinet i have now ordered with BT and i will get them to sort any fault if that is the problem as i have them to argue my case if they try to get out of it saying no fault
im actually closer to the cabinet than the neighbour yet there better speeds than me since i signed up ive heard nothing but horror stories
Thanx for noticing i had my number on i didn't see that
Message 18 of 24
(462 Views)
02-02-2014 7:17 PM
there line may take a shorter route? I must log a fault then as BT estimate me to have better speeds.......
Anyhow, Enjoy the same speeds with BT because you can't run from DLM
Message 19 of 24
(462 Views)
02-02-2014 7:22 PM
^ points to internal wiring / sky filter ect ect if next door is in the same cabinet which corresponds to bt impacted range guide...
Message 20 of 24
(462 Views)
02-02-2014 7:37 PM
Quote from: thesawdust there line may take a shorter route? I must log a fault then as BT estimate me to have better speeds.......
My line is shorter to the post and closer to the box than theres
Message 21 of 24
(462 Views)
02-02-2014 7:57 PM
Are you sure 100% next door are on the same cabinet ( cab numbers are shown on the that adsl checker)
Still hazard a guess that if the Openreach modem is connected in a line test configuration with everything else disconnected the speed would be in range A.....
http://www.kitz.co.uk/adsl/troubleshooting.htm
If it is an internal wiring issue after the the master socket then the \£150 bill lands on the customers mat
So it always worth checking in test set up whichever Isp your with ...... ;).
Best of luck with BT retail....
https://community.bt.com/t5/BT-Infinity-Speed-Connection/bd-p/BTInfinity
Message 22 of 24
(462 Views)
02-02-2014 8:04 PM
The box in my living room was new 11 days ago the wiring from there to bt router was new in box
They also connect to same cabinet
Message 23 of 24
(462 Views)
03-02-2014 11:03 AM
Have you raised a Fault Ticket with us at all so we can have a look at the problem?
Message 24 of 24
(462 Views)
- « Previous
- 1
- 2
- Next »
