fibre optic question
- Re: fibre optic question
19-05-2014 1:42 PM
I currently get 35mbs download speed and was wondering if this speed is likely to increase on RFS date set : 30/06/2014.
sam knows shows ...
roadband availability overview
ADSL:
Yes
SDSL:
Yes
LLU services:
Yes
Cable:
Yes
Wireless:
No
BT Wholesale information
ADSL status:
Enabled as of 31/01/2004
ADSL Max status:
Enabled as of 31/03/2006
SDSL status:
Enabled as of 14/02/2005
21CN WBC status:
Enabled
FTTC status:
FTTP status:
Wireless broadband availability
Now Wireless:
Not available
Urban Wimax:
Not available
Kijoma:
Not available
EMNET Notts:
Not available
Orbital / VFast:
Not available
Cable Broadband Availability
Virgin Media:
Available in some areas
Smallworld Media:
Not available
Who are all of these providers?
Spotted an error? Let us know
Location Map
Zoom Map
LLU operator presence
AOL:
Not available
O2 / Be:
Not available
C&W:
Enabled
Digital Region:
Not available
Edge Telecom:
Not available
Entanet:
Not available
Fluency:
Not available
KC (Kingston):
Not available
Lumison:
Not available
NewNet:
Not available
Node4:
Not available
Pipex:
Not available
Redcentric:
Not available
Rutland Telecom:
Not available
Sky / Easynet:
Not available
Smallworld:
Not available
Spectrum:
Not available
TalkTalk (CPW):
Not available
Tiscali:
Not available
Tiscali TV:
Not available
WB Internet:
Not available
Zen Internet:
Not available
thanks
sam knows shows ...
ADSL:
Yes
SDSL:
Yes
LLU services:
Yes
Cable:
Yes
Wireless:
No
ADSL status:
ADSL Max status:
SDSL status:
21CN WBC status:
Enabled
FTTC status:
FTTP status:
Now Wireless:
Not available
Urban Wimax:
Not available
Kijoma:
Not available
EMNET Notts:
Not available
Orbital / VFast:
Not available
Virgin Media:
Smallworld Media:
Not available
Location Map
Zoom Map
AOL:
Not available
O2 / Be:
Not available
C&W:
Enabled
Digital Region:
Not available
Edge Telecom:
Not available
Entanet:
Not available
Fluency:
Not available
KC (Kingston):
Not available
Lumison:
Not available
NewNet:
Not available
Node4:
Not available
Pipex:
Not available
Redcentric:
Not available
Rutland Telecom:
Not available
Sky / Easynet:
Not available
Smallworld:
Not available
Spectrum:
Not available
TalkTalk (CPW):
Not available
Tiscali:
Not available
Tiscali TV:
Not available
WB Internet:
Not available
Zen Internet:
Not available
thanks
Message 1 of 7
(1,215 Views)
6 REPLIES 6
19-05-2014 1:52 PM
Your present speed is impossible on ADSL - do you mean 3.5Mbps
Fibre speed is governed by your distance to the fibre cab so while a speed increase is likely there is no guarantee until the cab goes live and you can check the expected speed
Message 2 of 7
(746 Views)
19-05-2014 1:54 PM
I have had fibre optic installed today and am getting 35mbs,
I am confused what difference
FTTC status:
FTTP status:
will happen on the 30/06/2014
FTTC status:
FTTP status:
Message 3 of 7
(746 Views)
19-05-2014 1:56 PM
wwffan2, you need to search your phone number as opposed to post code to get a more accurate outcome.
If you submit your phone number here: http://www.samknows.com/broadband/broadband_checker What does it tell you?
Message 4 of 7
(746 Views)
19-05-2014 2:02 PM
I just did that and it says
However, there is another service on your phone line (e.g. ADSL, LLU, DACS, etc) that would prevent you from ordering a new ADSL connection.
The following services are available in your location:
BT Wholesale ADSL
BT Wholesale ADSL Max
BT Wholesale WBC (21CN)
BT Wholesale SDSL
BT FTTC
Bulldog LLU
But I had fibre installed today is it possible my speeds will go up ?
BT Wholesale ADSL
BT Wholesale SDSL
BT FTTC
Bulldog LLU
Message 5 of 7
(746 Views)
19-05-2014 2:08 PM
unlikely but try the BT speed test - further diagnostics
See the sticky at the top of this board
With that result we can see if there is room for an increase assuming you are on Unlimited and not Essentials
Message 6 of 7
(746 Views)
19-05-2014 2:10 PM
Quote from: wwffan2 However, there is another service on your phone line (e.g. ADSL, LLU, DACS, etc) that would prevent you from ordering a new ADSL connection.
This is because you currently have a service on your line.
Quote from: wwffan2 But I had fibre installed today is it possible my speeds will go up ?
No, it sounds like you're actually getting faster speeds than the estimated speed for you line. The date mentioned 30/06/2014 is the planned date for FTTC to be available in your area and that may still be the case for some people in your area, however, your line will not have any work done to it to "improve speeds".
Message 7 of 7
(746 Views)
