factory reset
- factory reset
factory reset
04-08-2012 1:44 PM
hi all
new to this forum,
i did a factory reset on my thomson tg585 v8,
and now the user name and password will not log me in to it
can anyone help?
new to this forum,
can anyone help?
Message 1 of 3
(1,059 Views)
2 REPLIES 2
Re: factory reset
04-08-2012 2:23 PM
Welcome to the forum.
I assume you are connected to Plusnet, just can't login to the router web interface.
The username for this should be admin (all lower case) and the password CP..., the 11-character serial number of the router which should be on the label underneath. All letters in the password are capitals, and be careful with 0 (zero) and O (letter).
David
Message 2 of 3
(558 Views)
Re: factory reset
04-08-2012 11:30 PM
hi thanks spraxyt
it worked a treet
it worked a treet
Message 3 of 3
(558 Views)
