extremely slow broadband - issues with telephone line
- extremely slow broadband - issues with telephone l...
- « Previous
- 1
- 2
- Next »
Re: extremely slow broadband - issues with telephone line
05-01-2009 1:12 AM
Depends on how you want to interpret 'update'
Message 16 of 21
(338 Views)
05-01-2009 11:22 AM
Thanks everyone for your help. I am in work at the mo but I just checked my speed on the plus net website and it's sitting at 2mb. The data rate on my router has dropped because the router dropped the connection yesterday evening. I think there was a problem with plus net last night?
I'll reboot my router remotely at lunch time today and see if the data rate increases, currently here are the figures:
ADSL Link Downstream Upstream
Connection Speed 2496 kbps 448 kbps
Line Attenuation 51 db 14.5 db
Noise Margin 14 db 18 db
again, thanks!
again, thanks!
Message 17 of 21
(338 Views)
05-01-2009 11:31 AM
Hi Brian,
I've just checked from this end and we're definitely profiling you on a 2Mbps data rate. If you reboot your router, you should start seeing improved download speeds
Message 18 of 21
(338 Views)
10-01-2009 12:06 PM
Just to follow on from my original query about my broadband speed being very low. This is resolved and I am now getting 2mb + synch rates.
I have been using a Belkin N1 wireless router modem since Christmas which I bought to improve wiress coverage in my house... trying to get a wireless signal in my sunroom for my wii. I plugged in my Netgear router (DG834G) and I noticed that there is about half a meg difference in synch rate between the two. The netgear being best. All of the ADSL settings are the same on both:
VPI = 0, VCI = 38, MTU = 1458 (was 1454 on Belkin but I changed this to the Netgear value)
Here are the speeds for both:
Belkin
Downstream Upstream
Data rate(Kbps) 2272Kb 448Kb
Noise Margin 14 18
Output power(dBm) 119 181
Attenuation(dB) 55 30
Netgear
Connection Speed 2624 kbps 448 kbps
Line Attenuation 53 db 15 db
Noise Margin 14 db 16 db
Is there anything that I am missing that may be causing the inconsistency between the two routers?
Belkin
Downstream Upstream
Noise Margin 14 18
Netgear
Message 19 of 21
(338 Views)
10-01-2009 12:09 PM
To misquote Animal Farm
Quote All routers are equal but some are more equal than others
Message 20 of 21
(338 Views)
12-01-2009 10:21 AM
Also as said before, it depends on the time of day that your router syncs, noise generally being lower in the daytime, but this can vary from one moment to the next if the line is a bit noisey. As you said about dropping sync. that other evening, having sorted your ring wire, I'd double check you don't have any internal connection problems, including connectors into sockets on all your extensions, you didn't say how many, and of course that the filters are good on all that you've got plugged in. If/when you're sure that's all ok, it's a case of moniotring your line noise. Also check you can't hear any crackling or other intermittent noises on your phone.
HTH.
HTH.
Message 21 of 21
(338 Views)
- « Previous
- 1
- 2
- Next »
