explain this
- Re: explain this
explain this
23-10-2007 12:26 AM
My IP profile is 3500 here is my connection details since the 1st 10
1/10/07 5120
2/10/07 4864
3/10/07 5056
4/10/07 4992
5/10/07 4448
6/10/07 5056
7/10/07 5088
8/10/07 5088
9/10/07 4992
10/10/07 5024
11/10/07 4864
12/10/07 4864
13/10/07 4896
14/10/07 4992
15/10/07 4832
16/10/07 5024
17/10/07 4832
18/10/07 5024
19/10/07 4960
20/10/07 4864
21/10/07 4960
22/10/07 4864
My IP profile often drops to 3500 why when I never connect at less than 4500 sometimes my profile can be 3500 in the morning and go up at the end of the day to 4000 and then its back down again.
I think I should get 4000 or 4500 90% of the time
1/10/07 5120
2/10/07 4864
3/10/07 5056
4/10/07 4992
5/10/07 4448
6/10/07 5056
7/10/07 5088
8/10/07 5088
9/10/07 4992
10/10/07 5024
11/10/07 4864
12/10/07 4864
13/10/07 4896
14/10/07 4992
15/10/07 4832
16/10/07 5024
17/10/07 4832
18/10/07 5024
19/10/07 4960
20/10/07 4864
21/10/07 4960
22/10/07 4864
Message 1 of 7
(1,833 Views)
6 REPLIES 6
Re: explain this
23-10-2007 1:39 AM
The IP profile steps are as follows:
Your list shows just one example on 5/10/07 with sync speed below 4544 (i.e. 4448) which would give a 3500 profie.
Sync speed | IP Profile |
from (kbps) | (kbps) |
3424 | 3000 |
4000 | 3500 |
4544 | 4000 |
5120 | 4500 |
5696 | 5000 |
David
Message 2 of 7
(477 Views)
Re: explain this
23-10-2007 1:49 AM
that was on the 5th but its still 3500
Message 3 of 7
(477 Views)
Re: explain this
23-10-2007 2:02 AM
Probably a silly question but could there be lower syncs between those you recorded? You should have a 4000 profile if the only ones are those quoted.
PN can check the sync history record.
Do you turn your router off completely overnight?
David
Message 4 of 7
(477 Views)
Re: explain this
23-10-2007 9:15 AM
Hi Samuria,
Any chance I could have you username? It's apparently not tagged to your account so I can't get the details I need in order to check your sync reports.
Message 5 of 7
(477 Views)
Re: explain this
23-10-2007 2:46 PM
username =mwright the router is turned off every night
Message 6 of 7
(477 Views)
Re: explain this
23-10-2007 2:58 PM
BTs records are suggesting that there was a resync at 4000Kbps on the 21st.
It should pick up again in 24 hours or so.
Message 7 of 7
(477 Views)
