exceptionally slow broadband
Fixes: 1,600
Re: exceptionally slow broadband
No problems at all Steve
Let us know if you need any further help.
steve991
Hi Folks
Im afraid its still dropping out. I fiddled with the router settings and set it to 300mbps as it was on 150, and used my wi-fi scan facility on mac (if you hold down the option key and click on wi-fi icon it reveals itself) to get the best channel.
best
Steve
MatthewWheeler
Fixes: 479
In that case I'm afraid there's not much further we can do.
Do you have any other devices that connect over Wi-Fi and do they have the same issue?
 Matthew Wheeler
steve991
Hi
I've an ipad, iphone and mac mini, all connected via wi-fi.
best
Steve
Fixes: 1,600
From what I can see your line seems to be dropping again as opposed to your WiFi signal.
Line tests aren't showing the cause of the problem. Would you be able to raise a fault to us at http://faults.plus.net letting us know over here once you've completed the troubleshooting steps it runs you through?
steve991
will do, thanks Anoush, have a good weekend
Fixes: 1,600
No problems Steve. You too!
steve991
well, ive tried to register a fault, but on testing the phone via the website something went wrong, this might be due to the fact that my phone is ancient, it works on pulse not tone, ie analogue. So cant register a fault
Fixes: 1,600
I've raised the fault from this side on your behalf.
Could you try the steps Here?
If you're still having issues let us know over here and we'll arrange an engineer visit to further investigate.
steve991
Thanks Anoush, you work too late, hope they pay you well.
best
Steve
Fixes: 1,600
Someone has to make sure the Internet doesn't run away. Tongue
Evidently I've failed as your connection is dropping.
steve991
Done a test in the master socket
Screengrab attached of speed test:
Fixes: 1,600
Thanks Steve.
As your connection is dropping it may be worth keeping an eye on this and let us know if the drops continue/your speeds remain slower than normal.
steve991
will do!
thanks for all help
Fixes: 1,600
No problems at all
