exceptionally slow broadband
steve991
Hi Folks
my broadband has been incredibly slow ever since I joined Plusnet, its like dialup.
My line looks ok physically, so must be settings? it comes over standard copper line.
Be grateful for any help
Cheers
Steve
56 REPLIES 56
Fixes: 1,483
Re: exceptionally slow broadband
Welcome to the forum Smiley
If you can post the stats from your router it will help to determine where your issue may lie, see https://community.plus.net/t5/Library/Broadband-Faults-Guide-Speed-EPP/ba-p/1322783 if you need help
steve991
Thanks Dvorak, I'll do that
best
Steve
adamwalker
Fixes: 221
I can see that the connection is dropping out quite frequently.
Line tests don't show any obvious issues so I'd try following the checks here next: https://goo.gl/tu2WWu
Let us know how you get on please.
 Adam Walker
steve991
Hi Adam
My broad band is still incredibly slow, can you please have a look? its slower than dial up.
Kind regards
Steve
Fixes: 1,600
Hi Steve.
Line tests aren't showing the cause of the problem so I'd recommend reporting a fault to us at http://faults.plus.net
Let us know over here once you've done so and we'll be happy to pick it up.
steve991
ah, just checked the router, a plug wasnt fully in, its still not massively fast though...
Fixes: 1,600
Can you check your speed in about 5 mins? I've reset your line as your speeds seem to have been restricted.
steve991
Many thanks for quick ply, will do
steve991
H there
I'm getting 13.2 download mpbs and upload is 1.0 mpbs
best
Steve
Fixes: 1,600
That's looking a lot better Steve. Thumbs_Up
steve991
Hugely! Thanks so much for rapid help
best
Steve
Fixes: 1,600
No problems, anytime Smiley
steve991
hi Again
I've been away for a week and my broadband is now back to glacial speeds, its incredibly slow again
could you have a wee look?
many thanks for previous help
Best
Steve
steve991
Thanks Gandalf!
all best
Steve
