engineer appointment
- engineer appointment
- « Previous
- 1
- 2
- Next »
Re: engineer appointment
28-01-2014 2:36 PM
Your supplier theoretically can hold it forever with a address mismatch?
28-01-2014 3:13 PM
And yes, I believe so, though only due to being unaware of it - this is the only situation in which it's cropped up.
28-01-2014 3:27 PM
There has to be some sort of time limit where it can be escalated, I am not going to sit here and accept we hope it will be done in 72 hours if not we will try again and wait another 72 hours.
I will check back here thursday.
28-01-2014 3:34 PM
30-01-2014 3:33 PM
30-01-2014 3:38 PM
EDIT: To clarify, I'll be able to request an escalation once the reply I'm due is late, i.e. it's past the time I was told I'd have a reply by.
30-01-2014 3:42 PM
Anyway since you want to wait for this new 72 hours I will check back with you tommorow afternoon.
30-01-2014 3:46 PM
31-01-2014 6:27 PM
so you waited 3 days, you are not in (you would know this 3 days ago?) and its not worth you raising it.
Maybe I have a db mismatch on my direct debit and its not worth me fixing it how would plusnet respond? they would expect me to fix payment quickly.
Its quite simple from where I sit.
You are my isp, its not my problem you have some sort of problem doing the booking, I expect you to simply do it. All this seems a bit laid back, doing a email to an agent, waiting for 3 days, then you not in so you cant be bothered to raise an escalation. Meanwhile if I ever do get an engineer he/she will turn up weeks after the fault is reported making his/her job much harder.
03-02-2014 10:33 AM
As Matt has now left, I've been handed this issue over. First of all, I'm really sorry for what can only be described as a ridiculous turn of events which has lead to you not having an engineer sent out. I'm completely in agreement with you that it's entirely unacceptable that an engineer has not been able to be sent out due to a data mismatch on our suppliers systems.
I believe that this issue has been cleared now and I should be able to book you an engineer. Could you advise when you'd be available for such a visit so I can get that arranged for you?
03-02-2014 4:51 PM
- « Previous
- 1
- 2
- Next »
